Question about HTC Touch Diamond Smartphone
How do i open my lock touch pad - HTC Touch Diamond Smartphone
  • kenneth_pack Jun 02, 2010
    My touch pad is locked with a password
  • HTC Master
  • 6,993 Answers
please could you rephrase your question? Is your touch pad locked with a code or what?
I look for ward to your reply.
Bye for now.
Posted on Jun 02, 2010
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
Maytag quietseries300 dishwasher in panel lock - can't unlock
depress the lock emblem on the touch pad and hold it down for 5-10 seconds. If the light lock does not go off then that means your LED touch pad is defective. Check in your owners manual for any warranty information on your touch pad. Most maytag offers 5 yr limited warranty on electronic parts which covers your touch pad.
thanks.
Dec 12, 2010 | Dishwashers
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Oven Fault Codes
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
No cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
Jul 30, 2009 | Compaq Presario CQ60-204NR Notebook
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
Nov 19, 2007 | Dell Latitude D800 Notebook
HTC Touch Diamond Smartphone Logo
23 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
