Question about Nikon COOLPIX S200 Digital Camera
When I try to turn on my camera, the lens won't open all the way and it says "lens error." I have found out that there are sand particles in the cracks of the lens, so how do I get them out?
  • 94 Answers
This is a major stripdown and clean, not reaaly a DIY job sorry
Posted on Jun 02, 2010
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
When pressing the power button, the shutter opens, the lens comes out, the screen comes on for about 2 seconds. Then the screen turns off, the lens goes back in, but the shutter stays open. I let someone...
Look closely for sand particles that may be lodged around the gaps of the lens barrel. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Kodak Easyshare C182 12MP Digital Camera
I was using my camera on the beach earlier and im not sure if sand got it in but i was using it and a minute later i turn it off and then try to turn it back on but a black screen appears and tells me...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try. Pay particular attention inspecting around the gaps of the circumference of the lens barrel for any sand particles. A single grain stuck in those narrow gaps can jam the barrel.
Nov 23, 2010 | Canon PowerShot SD1100 IS Digital Camera
Lens error, restart camera
Sir,
The problem seems that miniscule dust/sand particles jam the gears which moves the lens.
It is possible to turn the lens motor by hand bit by bit and remove particles stuck in the gear.
Also try restoring the factory settings and resetting the camera and seeing if that makes the error to go away. To do that, hold down the Menu button for five seconds. This should reset everything and (hopefully) make the error stop. If it doesn't, then you've got a separate problem-- come back and let us know if the error is still there. Also, if you have photos stored on the camera's internal memory, resetting the camera will delete those so make sure to download them first.
Thanks
Aug 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My daughter dropped her sister's Nikon Coolpix S560 in the sanddunes today with the lens open. It still took pictures after that but the lens wouldn't close. Now it opens and closes and makes a grating...
It seems that some sand particles are lodged between the lens casing and the camera's body. and when it finds that there is resistence in moving the lens, it shuts down. Use somethig that sucks, like the vacuum cleaner to **** the sand particles out. Do not blow, else the sand will go further in.
Aug 06, 2009 | Cameras
Lens error was at beach no sand but yet when turned on it says lens error
Anyone who has ever been near the beach knows that as soon as you are within 100ft of the sand you will feel sand in between your toes even with your sneakers and socks on. That's because sand is in the air and contaminates everything. Therefore, if you value your camera, mp3 player, radio, cellular phone PDA, or laptop computer, DO NOT TAKE IT anywhere near the beach. Solution: use an air compressor. Blow air & dust through the hose first. Use clean air to blow out extended lens area. Open and close lens and blow out several times. Firmly jolt the camera into the palm of your hand to dislodge the dirt particle. Use more air. You may notice sratches on the side of the lens cylinder that were created by the particles of sand. 99% pure isopropyl alcohol (91% if you're in a pinch is available at any drug store) can also be used on a Q tip and swabbed around the lens barrel cylinder. Make sure you use a few CLEAN Q tips on the lens. Now go buy a disposible camera and $10 mp3 player for the beach and leave the $200+ camera and IPOD at home or at the hotel room. Now you'll surely have a wonderful time at the beach.
Jul 28, 2009 | GE A730 Digital Camera
Canon S3 Lens Error
There two possible scenarios:
1. Sand particles got stuck in the internal lens mechanism. Try in remove them with compressed air, blowing it through the camera lens openings. If this does not work, then here are the bad news.
2. Either the lens internal gears are damaged, the ultrasonic motor is damaged, or sand particles are really stuck inside the lens.
It does not matter which of the three reasons are casuing the problem, but the camera needs to be opened by a qualified technician, defined thereason of the failure, and quoted the repair service, unless you are willing to do it yourself, but it requires a complete disassembly of the camera, and I don't recommend it unless you have the experience and skills in fixing electronic devices.
Best regards,
Jul 12, 2009 | Canon PowerShot S3 IS Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
3. Turn camera on
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Camera problem
There is sand inside the lens, this is quite normal if camera had been in contact with sand, you won't fix it by taking battery out, try blowing on lens gear, in attempt to remove sand particle, you can also use a compressor, like the ones at the petrol station.
The right thing to do in this situation is taking the camera for repairs, as the lens barrell must be opened and cleaned.
See if you can unlock it by chance in the way suggested, if not you will have to take your camera to a repair shop.
Check your guaranty terms.
Aug 14, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Need to clean
Hello sticky, This is a lens assembly mechanism problem. It is a delicate part of any camera. Altrought some people may sugest you to use a compressed air spray to remove the sand in the inner lens by blowing it out i don't recomand that because sand particles can be pushed out even further in the lens and could be causing even more damage. The lens assembly is composed of several servomotors, coils, some sensors and the actual lens. It does the following jobs: it extends the lens back and forth achieves focus by moving the lens zooms the lens by rotating them in the same time as the whole objective is moved back and forth Each of these operations is controlled by some servomotors who actually move these parts and are also connected to some sensors that pass the readings back to a main processing unit. When you open the camera this processing unit will check to see if the lens assembly is able to do all of these 3 things. Failure to comply with even one of them will result in some error (lens error) or simply having the camera not opening. "Lens error" or "zoom error" is a generic message, doesn't mean that the lens itself are damaged, could be the connector to their servomotors, sensor failure, some coils that are out of position and things like that. In your case the sand particles are preventing the servomotors to properly align the lens. They are all related to the lens assembly. Because this is a VERY fragile part of any camera I don't suggest you to try a DiY repair because you can damage the lens even further. Even service centers have problems repairing this, most time it is done under a microscope and some times it simply can't be fixed. This problems occur most of the time in corelation with the camera being dropped or received some shocks but even some small particles or sand in your case, can cause this problems as you can see. I would recomand you to go to a service center. Try not the big ones that represent large corporations (because they are expensive), instead look for a smaller one. Tell them you have a lens assembly problem, also tell them that it's caused by sand, ask them to make you a diagnostic and then ask for a cost estimate BEFORE they actually repair the camera. If the lens assembly is damaged beyound repair it will need to be changed as a whole, including all connectors, CCD sensor and so on. This could cost from $70 - $200 excluding labor parts that can be about $100. Therefore you should ask them a cost estimate. I'm sorry for not being able to provide a DiY solution but like i've said, i don't recomand one. In the future try not to expose the camera to any shock, sand or excesive dust and temperature variation. These are all known to give a great deal of trouble with digital cameras. If you need more info please post back. Good luck.
Apr 02, 2007 | Olympus SP-310 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
88 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
