Question about Sony Cybershot DSC-S950 Digital Camera
Error message saying Reinsert memory stick
Hi i am getting error message saying Reinsert the memory stick? any suggetions on thsis?
I have been using this memory stick for one year and i am getting this messge in middle of my vacation, i dont want to lose all snaps which were taken, if i insert this into camera it gives this message if i insert this into laptop then it does not recognize the memory card
Please help me find some options
  • 94 Answers
Buy a new card for the rest of the vacation, the new Sony cards come with free recovery software that may help recover the images on the old card?
Posted on Jun 02, 2010
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Apr 04, 2011 | Sony Cybershot DSCW310 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
My sony keeps saying Reinsert the memory stick?
The error message "Reinsert Memory Stick" may occur due to the following reasons:
1. The inserted Memory Stick media is not supported for use with the Camera.
=Ensure you are using the supported type and capacity of Memory Stick media for use with the Camera.
Please click on the below link to check for the compatible Memory Sticks with the Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12
2. The terminals on the Memory Stick media are dirty.
=Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up.
3. The Memory Stick media is damaged.
=Use different Memory Stick media and check if the issue persists.
Mar 05, 2010 | Sony Cyber-shot DSC-W190 Digital Camera
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Memory stick error when camera is turned on
Hi
How about download the user manual from this link
http://www.docs.sony.com/release/DSCV1.pdf
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
Memory stick error
your memory card has a virus! try formatting using camera. make it a habit that whenever you reinsert the memory card in your camera format it first before taking shots, this will erase everything including virus!
Sep 14, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony Cybershot DSC-S950 Digital Camera Logo
329 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
