Question about Bunn NHB Coffee Maker
Our Bunn was a gift and it has a leak. The tank leaks out from under the maker. It always has and we have to keep a towel around it.
  • 2 more comments
  • Anonymous Jan 14, 2009
    Our Bunn also leaks after it has brewed a pot of coffee. We remove the basket and put a cup to catch the water .I've removed the spray head and water still leaks.
  • eestine Feb 01, 2009
    I have the same problem, I tried the nut trick and it was loose but after I tighten it, still leaks. Gene
  • robtowell11 Feb 03, 2009
    I have had the same problem on two Bunn coffee makers now. The first one occurred within three weeks of owning it, so I recieved a new one for free. This time the machine is around three years old so I'm not sure what is going to happen. I just finished unplugging the unit and I am going to take it apart to investigate.
  • catmat50 Mar 06, 2009
    We just replaced our old Bunn coffee maker (at least 5 years old) that was leaking from the bottom. Our new one (about 2 months old) is now doing the same thing but worse. My husband took it apart, but couldn't find a screw to tighten like the old one had. HELP!!
  • 189 Answers
It sounds like you have a defective seal/gasket. If you will get the model and date code from the bottom of the brewer and contact customer service, your brewer can be replaced. If the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Posted on May 19, 2010
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
Unit leaks water from bottom bunn pouromatic
What model of Bunn is this? If it is a bx-b or any of the other home models, what has happened is that the plastic pour-in tray has become brittle and cracked where it mounts onto the tank. The only repair for this is to replace the tray with one from another brewer (possibly your local bunn Dealer has an old brewer lying around). If it is a commercial brewer (VPR, VPS, Ect) there will be a sael leaking on the top of the tank.
Nov 26, 2009 | Bunn Coffee Makers & Espresso Machines
Bunn coffee brewer leaking
Is this a lot of water, or just a small amount.
As the unit sits over time and runs heating cycles, it may have some vapor come out of the vents. That will cool and collect around the unit.
try turning the unit off for the weekends. If you still have water around the unit, then it may have a leak in the tank.
Nov 11, 2009 | Bunn VPS Coffee Maker
Bunn coffee maker leaks water only during operation...near end of the cycle (not when it just sits & not when water is first added).
There is a gasket where the water inters the tank,you have to remove the tank to get to it .mark down how it is wired so you can hook it back up.Use a high-temp
silacone ( auto ) and seal it under the the gasket and around the edge of the gasket.. 2 screws holding the metal plate plate. 4 screws holding tank need a 12 or 14 " phillips to reach down on the side of the tank to remove outer cover.
Oct 08, 2009 | Bunn NHB Coffee Maker
Leaking from top of water tank
It sounds like a broken seal/gasket. If you will get the model and date code and contact customer service, we will be able to properly assist you in resolving this problem. The machine carries a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced cost.
Aug 29, 2009 | Bunn NHB Coffee Maker
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
131 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
