Question about Ryobi Garden
Ryobi weedeater 4 stroke starts but only runs for a second or so I can get it to run but not well and I have to have some choke on to do it
We have a Ryobi gas weed eater. We can get it started but it doesn't stay on. I took it in to get it fixed and he said it was the primer switch, which he replaced, but we are still having the same problem.
Can you help us or refer us to a Ryobi repair store? We live in Phoenix, Arizona but can go to any repair store in Glendale, Tempe, Phoenix, Mesa, Scottsdale, wherever in Arizona. Thank you. Sally
Posted on Jun 26, 2010
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to start a Ryobi s430 4 cycle weedeater?
I have a husky 4 cycle I have to choke it and it is a bulgar to start once I get it running it runs like a champ just make sure you check your oil first
Oct 10, 2017 | Ryobi Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
I have a Ryobi RY28120 gas powered weedeater that will start sometimes and not at others. Not sure if the carb needs cleaning or if it need a new muffler. Maybe adjusting carb screws? Not sure! Also,...
Use only fresh gasoline (alcohol free if you can find it). Purchase a top quality synthetic 2 stroke oil such as Lucas, Golden Spectra and mix it exactly as the manufacture dictates. Install a new accurately gapped plug and make sure the plug wire cap (boot) is pulled back to inspect the wire to connector crimp. Start it up as you normally would to allow the new gas and oil to permiate the system and if you cannot get it to stay running without the choke being on shut it down and squirt some oil into the carburetor and pull the trimmer over, if this makes it start everytime it does not want to start and it allows you to click off of run you have either low compression (rings are worn). or your carb is yet another victim of the geniouses that thought alcohol in gas was a super idea. Either way you can replace the piston and rings or the carb. both are almost not worth the time and cost anymore, a new carb for mine is $70.00, with a new piston and ring set being around $40.00 and a brand new trimmer the same as this one on sale at $130.00 it was an easy decision to buy new.
Jul 18, 2014 | Ryobi Garden
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
How to start a kawasaki th48 2 stroke engine
Typically:
1. Press primer button 6-7 times until you see fuel flowing
2. Engage the choke lever to full choke /--/ pull cord 3-5 times until engine begins to start
3. Move choke lever to 1/2 choke and pull cord 2-3 times until engine starts - - allow to warm up (about 30 seconds) and move choke lever to no choke / / /
4. If engine does not start, repeat 1-3
If engine does not start, repost with more detail. Thanks! :)
Sep 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
My weedeater starts but doesnt seem to be getting enough fuel
You can't clean the filter. You can however order a new filter with the filter attached from www.ryobi.com.
When you say it's not getting enough gas is the weedeater shutting off on you? If so your carb may need to be clean. If that's the case then report back and I can tell you how to do that.
Mike
Aug 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 700r trimmer will not run without choke
First check the fuel lines for breaks, usually found at the tank. If lines are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), to clean the small portals in the carb. Reassemble and start. If it still doesn't run any better, then you will need to buy a carb. kit and replace the small screen, gasket(s), diaphragm, & needle valve.
Jim
Jun 05, 2009 | Ryobi Garden
Garden Logo
928 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
