Question about Kodak EasyShare Z710 Digital Camera
Flash prob How do you replace the flash?
  • djrabbit Jul 18, 2008
    I dropped my camera and the flash doesn't work what do I do? HELP !!!
  • Mike Johnson
    Mike Johnson May 11, 2010
    do you have it taken apart yet?
I have the same problem. The flash doesn't work after the camera was dropped. I'm wondering if I can purchase a flash and replace it.
Posted on Jun 23, 2008
Check engine light, flashing cruise control light
if you put a scanner on it you'll prob get a code telling you what prob is.if you have a autozone or,pepboys they could put scanner on it and tell you what prob is the only way
Feb 08, 2010 | 2007 Subaru Impreza WRX Sport Wagon
U have power and sound right?The backlight video inverter board is the prob.
Sep 29, 2009 | Sony QUALIA 006 Television
My right turning signal sometimes doesnt work. The light in the dash stays on, but doesnt flash. When this happens the front light stays on when the signal is applied, but the back one doent work. Ive...
  1. Turn 4 way (hazard) lights on check to see that all lights are flashing if rear is not flashing suspect bad ground since 4way usually goes through brake light.
  2. If everything flashes you may have a bad flasher relay find it replace it.
  3. If light still will not flash check light socket by removing bulb & looking for burnt melted contacts or plastic. You find any of these problems consider replacing socket.
  4. If you do not find any problems with socket use a cheap test prob connect alligator clip to metal ground near socket with bulb out turn on blinker carefully touch each contact inside socket when you find the right contact prob should light up & blink.
  5. If you cannot get prob to blink move prob ground to new location do step 4 again.
  6. If you still get no blink start probing wires coming into socket until prob lights working away from socket.
  7. Ground is on the side of the socket when you look in it.
Mar 08, 2009 | 1993 Dodge Shadow
My flash not working,showing flash chraging sign.
check batteries they are not giving enuff power for ur camera flash to get ready let me know if i can help further
Feb 23, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Nokia 3110 prob
flash its the operation that gives ur phone a new software/firmware.
and its very expesive its up to the repairshop.
the battery thing its the last thing u shud care about.
plz do rate this post as good as u can.
Oct 18, 2008 | Nokia 3110 Cellular Phone
89 justy wont start-no spark.
Doesnt the crank sensor use the flywheel for its signal maybe the sensor got damaged during the clutch job
Oct 15, 2008 | 1989 Subaru Justy
This is normally a problem with the flash. Try resetting all the options to default through the menu... I think Sony calls it 'initialize' but I don't have a W35 on hand to walk through the steps sorry.
Hopefully this will work. If not, you will have to replace the flash, but you may still have to clear the error message after replacing the flash and that takes specialized equipment.
Good luck
Oct 03, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
hi there, red light flashes means a shorted electronics componets is needed to be replaced. check for horizontal section prob. it maybe a flyback transformer, a transistor or diode. do some test. ty
Jan 29, 2008 | Philips 32PW6006 32" TV
F828 32x Flash conx probs
Do you have the camera set for flash? If it were set for no flash (diagonal bar thru lighting bolt) the F32X and the camera do not communicate.
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
Kodak EasyShare Z710 Digital Camera Logo
227 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
