Green flash came out of the back of sharp sx66nf8 tv when turned on. Now no power
  • 4,234 Answers
Flashes out of hte back are never a good sign. A part has fried. Without seeing the insides, I can't see what occurred. Look for a blown fuse first. I suspect that changing the fuse will result in the new one blowing as well. You probably have a problem in the main power supply area. Try replacing the fuse first and turning on the set. Report here with anything that occurs. For example, standby light, blinking etc.
Dan
Posted on Apr 09, 2008
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
I have an LC-32D33X sharp tv... it just turned off on me :( and now the OPC and the power lights on the tv are flashing SOS style :(
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
Mar 06, 2012 | Sharp LC Televison & Video
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Sharp LC -46SB54U will not turn on. The green power light flashes twice, then the green power light and green OPC light flash once together. This pattern then repeats itself over an over again. The tv is...
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
Jun 16, 2011 | Sharp LC46SB54U 46 in. LCD TV
Flashing green button
Where are you located? If you don't want this Sharp 35VX-H2000 anymore, I will take it, even if it's broken. Thanks.
Jun 29, 2010 | Sharp 35VX-H2000 35 in. TV/VCR Combo
Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
Apr 02, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My sharp aquos lc-c3242u turned itself off and now wont turn back on. i plugged it into a different power receptacle and the green light flashes but wont turn on. is there a way to reset the tv, or is...
If power light continuously flashing it means backlight problem. Two possible causes. One, backlight invertor is faulty. Two, but realy rare, one of the CCFL lamps went bad.
Dec 02, 2009 | Sharp Televison & Video
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
