Question about Kitchen Ranges
Kenmore Dryer. Try to start the cycle get 3 beeps and nothing happens.
    President:
  • 1,561 Answers
a dryer usually has a door switch that activates the working parts. Unless the door is properly closed, the dryer won't work, regardless of the settings on the control panel. makesure the door is well closed.
Many dryers are equipped with a reset button on the control panel. If the motor won't run, let the dryer cool for about ten minutes. Then push the reset button. If there are no problems with the motor, switches, or electrical system, this should restart the dryer. If not, then your machine will need some repair.
Take care.
Posted on Jun 02, 2010
  • Gene Strote Jun 03, 2010
    Its a newer kenmore dryer. Is there a way to go into diagnostic mode on the dryer. It has a computer board and front panel access.
  • Sulaimon Jimoh Olayemi Jun 03, 2010
    Since it is a newer dryer, i advice you refer to the manual to see the set up, you may be be missing something out, perhaps the timer and other settings. check the manual of the dryer for appropriate settings.
    Ascertain if the main wiring connection from the house to the dryer is
    broken. A dryer can tumble with partial power, but an
    inadequate connection with the main power supply to the house may be
    causing your dryer not to function. If this is the problem, you may
    need to replace the power cord that goes to the dryer as well as the
    terminal block that is attached to the wire itself.
    This
    switch, located on the control panel, is usually the push-button type.
    Start switches don't fail often, but it does happen. To check the start
    switch, remove the control panel and test the switch with a VOM set to
    the RX1 scale. Disconnect the leads from the switch terminals and clip
    one VOM probe to each terminal. Press the switch button. If the meter
    reads zero, the switch is working.
    Take care.
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Dryer beeps running
Hello Biff
You should the the following.
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
Best Regards
Neciforo Llanto
Sep 21, 2013 | Kenmore Dryers
Pushed a button but dryer does not start, can not push any other
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Kenmore Elite HE4 Electric Dryer
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE4 dryer 3 rapid beeps when pressing start button
the machine is in lock mode made for children in mind so that they do not touch any cycle while on,, look for lock icon hold 3 seconds and u will hear beep and that its it u r done ,,,,
Oct 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't run
take a look at your start and door switch
May 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kennore gas dryer # 110.87694110
you need to check the door switch and the start button first
Feb 11, 2008 | Kenmore 74602 Gas Dryer
HE4 Elite dryer beeps
The Thermal fuse is most likely the problem.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
