Question about Poulan "Poulan" Push Mower
Third time used. Has oil and gas. Spark plug is tight.Runs lengh of yard and then quits. If I wait 15 minutes and try to start, it will run about one minute and quit again. Could it be flooding?
  • 177 Answers
Yep carby service
Posted on Jun 07, 2010
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
RUNS 2 MINUTES QUITS WHAT A PAIN ED
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor is tightly fastened to the engine. Will it start and run another two minutes just after it quits? Try loosening the fuel cap to see if that affects the running time. When it quits, remove the spark plug to check for spark. If nothing, the ignition module may be failing. If it appears to be loss of fuel when it quits, the carburetor may not be pumping fresh fuel into itself--remove the carburetor and check the impulse passage that runs from the engine to the rear of the carburetor for leaks of any kind. Hope some this helps!
Dec 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Oil is fine, runs fine for about 10 minutes then bogs down and dies. Let it sit for 10 minutes it will start again and run fine for another 10 minutes. Used to be 20 minutes, then 15. The cooler the...
It could easily be an electrical issue, or not. Get a spark tester (hooks up to the spark plug). Pep boys, Autozone, and Napa all sell them for less than $10. Check for spark when the mower has quit. If no spark, most likely need to replace the ignition module. Also check the flywheel key, if it is has been sheared or even knicked, the engine will run hot.
If you still have spark when engine has failed, check the vent on the gas cap. A clogged vent will cause a vacuum to form in the tank and stall the engine.
Aug 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Runs for about 45 mins then shuts off
Hi there:
make sure to read the full post before to procceed, ok?
When it stops I supposse you try to start it again. What happens??. 1.-Runs again or you have to wait until it cool's off ??
If it starts but stops in the next minute you may have a clogged gas filter.
2.-If it has no gas filter, then you migth be having armature problems, to check just unplug the spark plug and use another one making sure the metal part is in good contact wit the metal part, be really careful the engine is going to be really hot, so use gloves and ask someone to pull the cord as if it were to run and look for spark, If no spark check the oil level to be correct, if so, then let it cool and try for spark if there's spark then the problem is your armature.
3.- Prior to do ANYTHING make sure there's enough gasoline in the tank. You won't believe me but happens quite often.
Jan 16, 2010 | Coleman Powermate Premium Plus 6250W...
Mantis 4 cycle (brand new): oil leaking out, smoking soaking air cleaner, quits running..
Sounds like your gas tank is not breathing properly. try this: the next time you run the tiller and it begins to stall out, try loosening the gas cap. It should start running again. This means that the gas cap is clogged. Unclog it or purchase another one.
Jim
May 30, 2009 | Mantis 4-Cycle Tiller
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Requires several times just to get started and then runs fine for about 5-minutes and cuts then cuts out on its own. Then have to wait for about 10-15 minutes to start again but still requires several...
The most likely problem is the ignition module. It is probably going out. when a bad ignition module gets hot from use, it stops working, which kills the lawn mower since there is no spark. Once it cools off it sometimes works. This can be a some what costly part, $60 - $80. You might want to take it to a lawnmower repair shop and have them check it out, since there are other issues that could be the cause to your problem. If you have a spark tester, you could test the ignition module to see if you get spark, both before you start the mower, and after it quits on you.
Mar 10, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Poulan "Poulan" Push Mower Logo
125 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
