Question about Dell 942 All-In-One InkJet Printer
The black cartridge holder clip with the spring broke off. Is this something that can be fixed? worth fixing? more to fix it than it is worth? It is on Dell 942 All in one printer
JackHeath
  • 1049 Answers
SOURCE: Dell 942 Error 1203
Error 1203 occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
Posted on Jul 28, 2008
  • 137 Answers
SOURCE: HP 7410xi small plastic piece in print cartridge carrier broken
If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Mar 02, 2009
SOURCE: My printer is broke and I need a part.
sadly you can't buy them they are not available. Me being an HP authorized service center can't even order them. Same thing with the Diagram of the printer. I do know what part you are needing it happens often i would suggest you go to the DI or find some one with a old one that has stopped working and steal the part off of it that is the only way i have found to fix them
Posted on Mar 19, 2009
  • 15 Answers
SOURCE: Dell AIO 942 Error 2200
I would recommend cleaning off the contacts where the cartridge is loaded as well as the any other spots to see if maybe there is just something on the contacts.
Posted on Sep 19, 2009
  • 159 Answers
SOURCE: Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Posted on Dec 28, 2009
How to fix broken hp6500 cartridge holder
Get HP Printer related all issues solved, contact and visit now... HP Printer Support
Aug 26, 2014 | Office Equipment & Supplies
How can I replace the two air vents on each side of the steering wheel on the dashboard of my 2004 Acura MDX? I was trying to hang a small holder with a clip that hooks onto the inside of each vent at...
This may be too late in posting. There are some great air fresheners that are a quick, inexpensive fix. The brand you want to look for is called Autoicon1.png Expressions, Ventfresh airfresheners. Pep boys in my area, colorado springs, has a better choice than autozone. They run about 3-4$ for a package of four. AE vent clips look better in the vents than Refresh and other brands which have big round white head that clash with the black.
Auto Expressions Vent Sticks: Wildberries Auto Air Freshener - 4 pk. ' Product Details ' Pep Boys
This is a link for what they look like.
Aug 19, 2010 | 2004 Acura MDX
X-spring tab broken in ink receptacle (HP officejet 7310)
I think you right. There are a lot of small parts which are finely tuned in a printer and most likely something else is still affected.
You probably are better off purchasing a new unit, unless you have the time and patient to figure it out.
Good Luck!
Sep 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Color printing not working
It sounds like the repair shop did not repair the cartridge holder properly, or they did not align it properly. If you can it would be best to take it back to the repair center and have them fix it correctly.
Aug 10, 2009 | Office Equipment & Supplies
Mar 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
Regards,
Dec 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Broken clip for black ink cartridge
Unfortunately, this is not an easy fix. To replace the ink cartridge holder, you would have to dissasemble the whole Print head/Carriage assembly. The when you put it back together , there are timing factors to be set. With printers so inexpensive, I would opt for a new unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 31, 2008 | HP DeskJet 5550 InkJet Printer
7310 office jet all in one - black ink problem
You are right about the "extended paper clip".
Here's what I found when this happend on my two 7410's. Take a look at where the ink cartridge slides into it's holder. Shine a flashlight on the circuit board at the rear. You will no doubt find it has a puncture in it that breaks the little tracer wires on the board. The culpret is the tension spring arm. It likely has come off it's base support and when that happens, and you install a new cartridge, the cartridge will push the tip of the tension wire g right into the circuit board. After you fix the circuit board, apply some silicone glue to the spring base mount to hold it in place. I hope I can find the part and remove and replace it easily. That I haven't done yet.
Mar 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Error message
I am prining envelopes and got this message twice so far. I just unplugged the printer for a hard boot. Wish someone knew what generates this message though. Annoying.
Feb 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Dell 942 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
