Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I have a RYOBI Expand it pruner attachment and the chain is not engaging on the saw. If I turn the drive shaft with my fingers where the attachment meets the main unit, everthing turns fine. Any ideas?
  • 4 Answers
Nonr
Posted on Jun 03, 2010
Chain binds when bar is tightened
visual check that the bar is not bent. ensure correct chain for the saw .different chains need different sproket tooth set ups. visually check this for proper full engagement.exactly how tight are you trying to get this thing? the chain may need a little slack to keep it from binding.
Jul 08, 2014 | Ryobi 2 Cycle Pole Pruner
I have a model PP335 string trimmer and have purchased a model PPB5500P pruner attachment. I installed the pruner directly to the shaft from the motor head, without the extension shaft. My problem is...
The pruner is not made to connect directly to the powerhead. The size of the hole and the size of the shaft are different. You must connect to the coupler for this to work properly.
Apr 23, 2017 | Poulan Garden
I have a RYOBI pole saw that starts fine, but there is a disconnect between engine and saw blade. The blade will not turn.
I assume you have the Ryobi powerhead with the multiple tool shaft (can use it with an edger, blower, trimmer, and pole saw) If so, does the powerhead square drive spin when you squeeze the throttle trigger? Does the chain move freely on the saw end when not connected? Is the attachment fully inserted into the powerhead shaft (small spring-loaded button should pop out of the hole when fully inserted.
Aug 26, 2011 | Garden
Expand-It ZR15520 Pruner Attachment oil container broke need new one, do u know i can get this? thx
Go here to start your pruner lookup process. You will have to agree to the terms on their site. Your part may come up under Ryobi but I feel it is the same part as the the Expand It one.
http://www.homelite.com/service_support/order_parts
Dec 11, 2010 | Homelite Expand - It 10" Pruner Attachment
Expand it zr15520 pruner attachment oil resavor clear cover has crack in held down with 4 screws do know were i can get this part pso4545 this number is under the cover when removed thx
I think Homelite Expand It and Ryobi use the same pruner attatchment. I found this one on a Homelite Parts site under Ryobi. Your part looks to be number 20 in the breakdown. I hope this helps.
http://tinyurl.com/2au56eo
Start procedure for chainsaw ncr 4550
The header says that this is an electric saw which doesn't have a start procedure--just push the button and it runs. Electrics also don't have a clutch because the motor doesn't need to continue running when not cutting like a fueled engine does. Most electrics, however, have a safety device that uncouples the chain drive sprocket from the drive shaft to protect the gearbox. Remove the bar and chain, then look for a broken/disconnected drive link or spring connected with the sprocket. If the shaft itself does not turn, then there is likely problems in the gearbox. Hope this helps!
Jun 03, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Where can i buy a replacement chain for the expand-it prunner emmanuel1942@yahoo.com
Lawnmower, Small Engine and Outdoor Power Parts from M&D - Site ...sacore:green.gif UP08688: UP08688 UP08688 HOMELITE PART UP08688 Replaced by: 6958301 > PS03873 CHAIN,3/8,.043,10 .... HOMELITE PART UT41002A19/UT41002A-19 KNOB FOR EXPAND-IT COUPLER ... ZR10926: ZR10926 ZR10926 HOMELITE PART ZR10926 Chain Saw 16" Ranger 33CC ... ZR15520: ZR15520 ZR15520 HOMELITE PART ZR15520 Pruner Attachment ...
www.m-and-d.com/siteindex476.html - Cached - Similar
Mar 26, 2010 | Homelite Expand - It 10" Pruner Attachment
Chain saw pruner blade will not turn
http://www.homelite.com/service_support Navigate to your pruner, order parts and you will find an exploded diagram of pruner. On mine , same problem, the Pinion assy @ $10 and the Gear assy @ $30 were both worn down to the point of non-engagement. They both have brass teeth. Special tools needed : correct torx bit and snap ring pliers. hope this helps.
Jun 04, 2009 | Homelite Expand - It 10" Pruner Attachment
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
661 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
