Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer may be overheating... breaker trips after dryer runs about 2 minutes.
  • 56 Answers
Your heating elements might be grounding out agianst the frame i would take the front of and ohm them out to the frame making sure power is of first
Posted on Jun 02, 2010
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Dryer was running then stopped
Some driers turn off when overheated. Wait for your drier to cool down and try again. You may need to clear the vent tube which accumulates lint not caught by the drier's lint catch.
An old dryer may be drawing too much power and may have tripped the breaker. Go to your breaker box and look for a switch that is not facing the same way as the others. Push it back in position.
A digitally controlled dryer may freeze like a computer. Try unplugging the machine for 1 minute, plug back in and try again.
Apr 16, 2012 | Dryers
Power Failure without tripping breaker
Sounds like an overheat code tripped due to obstruction in the exhaust. There is also a vent tube on the bottom of the dryer that could be loose.
Jul 27, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
220 dryer CH Breaker only trips partially and dryer does not reach full heat. Is breaker problem or dryer?
I would say that the problem is in the dryer, but only tripping partially is not exactly right either. It is easy and relatiuvely less expensive to replace the breaker . $40 .. if you replace the breaker and still get it tripping after a few minutes of opperating the dryer , then it is time to call a service tech for the dryer.
IF the breaker trips immediately when connecting the dryer, then unplug the dryer and try again, to see if there is a wiring problem in the line before the dryer.
Jun 05, 2010 | Cutler Hammer Ch220gf Circuit Breaker
My GE dryer DHDSR46EG 1WW less than 2 year-old dryer flips the breaker after about 10 minutes of drying
If the dryer appears to be running OK before the breaker trips, I might consider checking the breaker. Over time they can get weak and not hold the current rating.
If the dryer is smelling "hot" then we can look a little further.
Let me know.
Regards,
Aug 15, 2009 | GE Dryers
The dryer keep tripping the breaker
It sounds like the current draw is too high This would be due to overload of dryer, motor overheating binding of the drum assy.. First re level the dryer, next disconnect the power and Vacume out the lint inside around moter, try spinning the drum manually to see if it moves freely( some resistance is ok) Another possibility can be lose electrical connections on the breaker or outlet. Disconnect power before testing. Let me know if these tips helped solve issue
May 14, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is overheating and tripping the breaker after 40 minutes
Is the dryer tub turning as fast as it should? If not the dryer motor bearings or sleeves may be trying to seize causing the motor to decrease in speed therefore the lack of fan action will cause the dryer to overheat.
Apr 07, 2009 | GE DBXR463EDWW Electric Dryer
My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Feb 28, 2009 | Maytag Centennial 7.0 Cu. Ft. Super...
Fisher and Paykel DEGX1 Electric Dryer Logo
249 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
