Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
My dishes are not getting cleaned. Glasses are cloudy. The jet dry does not seem to be working. It is always full and usually I have to refill it often.
    Problem Solver:
  • 7 Answers
Use LESS soap. or none and use vinegar instead.
Posted on Nov 05, 2010
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on Sep 30, 2010
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
The dishwasher works fine but the jet dry doesn't seem to release to clear dishes. I have cleaned it out and put new liquid in. It always seems to be a the same level and never needs refill. Glasses are...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 02, 2011 | Maytag Dishwashers
After running my GE Nautilis there seems to be soap scum on all the dishes. I can't seem to get them clean. I have even tried using jet dry and yet the glasses still come out very cloudy. How can I fix...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 14, 2011 | GE Nautilus 24" Built-in Dishwasher
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
My dishes ang glasses are cloudy *** well as the doors
The cause of the cloudiness is usually due to hard water drying on the dishes and can turn into etching (or pitting) of your dishes. If you have particularly hard water it is well worth investing in a water softener or filters. 2nd; Use plenty of rinse agent (jet dry or similar). Rinse agent gives your dishes a sheen (almost like waxing your car) and helps the dishes dry quickly and cleanly. 3rd; Clean the d/w every 1 to 3 mths. using a good cleaner. Hard water deposits can be cleaned with a little CLR. Use GLISTEN to clean your d/w. Glisten is not found in grocery stores but can be found online or at an appliance parts shop for 5-6 dollars. Please rate this post.
Dec 15, 2009 | LG LDF6920ST Stainless Steel 24 in....
Our glasses are really cloudy. How do we clean the inside of the dishwasher?
This may be a hard water issue, but assuming it's not:
Pour 1 liter of white vinager into your dishwasher and run through a full cycle.
If this fails:
Pout 1/2 liter of CLR into you dishwasher and run through 3 full cycles.
N.B. Vinager is preffered as it's non-toxic.
Other possible issues:
hard water, lime/sediment buildup in hot water tank, not using rinse-aids like "jet-dry"
Sep 08, 2009 | Maytag Dishwashers
Cloudy Glasses
The problem is hard water and jet dry will not solve that. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Jun 01, 2009 | Dishwashers
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Film on dishes and inside dishwasher
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Aug 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
122 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
