Question about Uniden BC248CLT Base Scanner
Where can I order a new antenna? - Uniden BC248CLT Base Scanner
    Genius:
  • 1,274 Answers
Www.RadioShack.com ....get it at your local Radio Shack store......hope this helps..
Posted on Jun 03, 2010
1996 Toyota Camry. Need to replace broken antenna to get radio reception. Is this replaceable?
You can replace the whole assembly. It could be catered from junk yard, new Toyota parts store or car radio shops. After market antennas are also available which could be put to work after a little effort.
Apr 14, 2014 | 1996 Toyota Camry
Need to replace radio antenna on a 99 isuzu rodeo
I just replaced the antenna on our 02 rodeo. No need to remove radio or anything in dash. This is how I did it.
First you will need access to back of fender, enough room for your hand. Open hood and remove 3 bolts running along top of fender, open passenger door and remove top bolt holding fender. Gently pry top of fender away from vehicle. Place object in gap to hold fender ( I used the head of a rubber mallet). Reach inside fender and disconnect old antenna, follow cable through wall into passenger compartment. Gently pull cable from behind carpet and unplug old antenna from coupler. Connect new antenna to fender ( replacement antenna I ordered was slightly smaller than opening so I had to add washer). Run new antenna cable through wall and plug into coupler. Re-attach fender
Aug 23, 2012 | 1999 Isuzu Rodeo
Where can I order an antenna forthe CD BA 2100 stereo
Hi,you can find it any Electronic Store or even Hardware store..Just ask for " FM antenna Cable " of course this is a passive antenna.
.if you have any reception problem to get FM signals on your location ,than you need to buy" Active FM antenna" with amplifier.....before go to store pls take a look at the rear panel of your stereo to see and decide what kind of FM antenna plug you have it..
if you want to buy these thru ordering you can find thousands available in EBAY web site..
Below are 2 URL as different type..TERK is a successful antenna.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
http://cgi.ebay.com/Terk-Audiovox-AM-FM-Indoor-Stereo-Antenna-Gamma-Loop-/110716385684?pt=LH_DefaultDomain_0&hash=item19c735f994
http://cgi.ebay.com/New-DTV-HD-FM-Rotating-Indoor-Digital-Antenna-Remote-/230517606660?pt=LH_DefaultDomain_0&hash=item35abeb8904
Jul 23, 2011 | Sharp CD-BA2100 CD Shelf System
I need an antenna for a garmin 660
Here is a link to amazon were you can get a new antenna for around 15 the Garmin does sell stock antennas but they are 30 with a 1-2 order processing time so this would be quicker.
May 04, 2011 | Garmin Nuvi 660 GPS Receiver
I accidentally broke the antenna. How can I order just the new antenna to fit in it's place. How much would that be for RCD200 boom box? Thanks, debson621@yahoo.com
You would be better off sticking a thick copper wire where the antenna used to be. It wont look very pretty, but you will get a strong signal.
Oct 04, 2010 | RCA RCD-200 Radio/CD Boombox
Screen on tv just says no signal
When installing a new antenna, a TV will often need retuning in order to operate with the new antenna.
Using your remote, access the TV's menu (settings as oppose to TV guide) and you should be able to access a tuning menu, this may be located in Picture, or have its own section.
Select the setting for automatic tuning and you should find that the TV uses the new antenna to find its channels.
Aug 23, 2009 | Televison & Video
Procedures to install cb antennae mount
The end without a connector was once attached to an antenna. You need a proper antenna in order to use the radio. If you were to buy a new antenna, it will come with a length of cable attached. Even if you were to buy a new antenna, don't expect good performance from the radio unless you get the antenna properly adjusted. Yes, it will work "out of the box", but probably not as good as it could. There is a device called an SWR bridge, it's used to measure the SWR and the user then adjusts the antenna for the lowest reading by trial and error adjustment of the antenna.
Jan 23, 2009 | Cobra 18 WX ST II 40-Channels Base CB...
Replacing antenna on linksys wrt54g router
yes u can get a antena from retail store and get it and remove the old one and turn off the router and and connect the new one and turn on the router>rate me solved if its helps thx
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Install a new antenna i850 nextel phone
ok you will need a hex screw driver, remove the old antenna by removing a little black cover on the antenna which hides the screw. remove it, insert the old and remove the screw cover and screw it back in.
Oct 29, 2007 | Nextel i850
Uniden BC248CLT Base Scanner Logo
29 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
