This lesson cost me $104. Error code 4 could be the most common and easily fixed problem is a small item in the pump blades. The round cover on the bottom front covers a hand removable valve that gives you access to the pump. The item, ours was a panty liner, once removed will allow you to reset the machine. Any water in the machine will come our quickly once you open the valve.
Dear gavinrolason,
Error code F-04 and F-05
Check the the connection of the drainage hose to your sink wastage,
as it may be blocked and the drainage of water
impeded
Hope it helps, this info is applicable to W840/W860 Hotpoint Machines
Regards
EngineerGR
