Question about Sport & Outdoor - Others
Put new piston in motor. it starts and ideals fine but from ideal to hafe throttle after letting clutch out it boggs down and dies but from hafe to full throttle runs fine
  • tbjz Jun 02, 2010
    I HAVE REBUILTTHE CARBRATER EVEN TOOK IT TO A SHOP FOR CHECK.I WAS WOUNDERING IF THERE IS SOMETHING WRONG WITH THE NEW PISTON
    President:
  • 1,619 Answers
Did you make sure the piston rings and oil ring gaps were not all lined up? Did you make sure the correct gap was achieved on those rings?
Posted on Jun 02, 2010
    Top Expert:
  • 76,073 Answers
You have a carburetor problem, suggest u rebuild it, the main jet is plugged i suspect with a piece of dirt.
  • 2 more comments
  • tbjz Jun 02, 2010
    tryed two differant carbraters and it did same thing. it dose have adjustable main jet and no idea were. it should be set
  • yadayada
    yadayada Jun 02, 2010
    check and make sure u have a clean fuel supply, because this is a crab problem, and there is no such thing as an adjustable main jet, it is a piece of brass with a hole drilled in it that screws into a well in the carb body inside the float chamber, both these carbs where rebuilt and inspected?
  • tbjz Jun 02, 2010
    have tryed two others and they did SAME THING BUT IT DOSE HAVE AN Adjusatable main jet and i have no idea WHAT SETTING IS NEEDED.
  • yadayada
    turn it so it is richer, a jet is a fixed orifice, so think we have a communication problem here, done 100's of carbs , was the carb cleaned with carb spray and compressed air? is the fuel supply clean and from contamination? u are sure of this.
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
I let the clutch out the motor wont run
The motor wont run or the car will not move ?? If the car will not move sound like its time for a new clutch . If the engine is stalling out you might need to raise your ideal speed or let your clutch out slower and give a little ore gas.
Apr 11, 2014 | Cub Cadet Garden
Can't get the ideal set right
Is the exhaust converter over 12 years old
& restricted
How about mechanical timing of motor
Low idle- you check engine vacuum & timing,
as well as ignition timing
Have to stay with the so called old school basics
people seem to forget about
How about vacuum leaks,fuel pressure,battery
voltage,alternator problems
It all effects todays electronic vehicle systems
Mar 01, 2013 | 1994 Toyota Pickup
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
My 1999 crown victoria has been dieing when at ideal somtimes has rough ideal, but runs good when im driving, and the ideal will go to normal if i put it in neutral at stops. and somedays it just runs...
p1409 is a fault code fo the stepper motor in the EGR-usually they get dirty from carbon and you need to remove the EGR and clean it with throttle body cleaner. This egr (exhaust gas recirculation) stepper motor code is best checked by physically having a look at the bottom of the egr stepper motor. When the vehicle engine has a lot of mileage, a carbon build up will occur at the pintle rod at the bottom of the motor and make the exhaust gas passage difficult causing the code. When removed, the carbon can be clean and pintle rod freed up so that it moves. Yours is stuck open, causing poor idle since it is introducing exhaust gas into the intake manifold during idle, which if operating properly it will not do at all.
Oct 04, 2011 | 1999 Ford Crown Victoria
2004 Honda, 1100 Shadow Spirit, starts fine, ideals fine, but when I put it in gear it dies
Hi, David_rebeka and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Dies when put it in gear 2003 Honda Spirit VT 750
Put the bike in gear and engines dies
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 29, 2011 | 2004 Honda VT 1100 C Shadow Spirit
I have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
