Question about Dryers
I cannot get into Kenmore Elite dryer to install propane conversion
  • 494 Answers
To remove the top, you will need a medium size flat screw driver and a flashlight. Some of this procedure is a lot easier with a 2nd person, so have someone else with you to help, if possible. First unplug the dryer and turn off the gas valve behind the dryer. You are going to want to use the screw driver to push 2 metal tabs to release the top panel from the front panel. Apply some lifting pressure to the top panel while looking into the gap (with the flashlight) between the top and front panel. Look for 2 metal tabs, which are usually painted black. When you find them, push them (one-at-a-time) forward horizontally with the screw driver until you hear it pop and release. Once you get both metal tabs released, you can lift the top panel. NOTE: This is where you need a 2nd person to help. Before you lift the top panel, have someone else hold the front panel. The drum rests on the front panel and will fall down without it's support. You will also need to disconnect a few wires to remove the front panel. Take note where they hook-up for reassembly. Grab hold of the drum and have the 2nd person pull up on the front panel to remove it from the grooves at the bottom. Find something or someone to hold up the drum, so you can work hands free on the dryer conversion. If you need more assistance to do the conversion, just let us know!~Good luck!
Douglas
Posted on Jun 03, 2010
How do you revert a Kenmore Elite He5 gas dryer from propane to natural gas. Is it just changing out the orifice?
a little more than the orifice needs to be changed the pressure regulator and on some the whole gas valve body
Sep 24, 2016 | Kenmore Dryers
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Converted a kemore from gas to propane now it doesnt get very hot and takes forever to dry
Normally natural gas appliances have a different nozzle size than the propane units. i would check with your propane/gas dealer to make sure.
Mar 02, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
How do i convert gas dryer to propane kenmore elite
kenmore has instructions along with the correct orfices you need to burn propane the only difference between gas and propane orfices is the hole size in the center of the orfices and there is very little difference in size propane is smaller hole because the pressure difference between natural gas low pressure proppane higher pressure
Jan 13, 2013 | GE GFDS350GLWW Dryer
I have a Kenmore Elite electric dryer and would like to convert it over to propane how dso I do this?
get a conversion kit from the manufacture,thats if it can be converted....maybe there is a aftermarket conversion kit...check with your local appliance repair outlet.
Jul 17, 2010 | Kenmore 73952 Gas Dryer
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Older Frigidare Elite Dryer conversion
You'll have to contact Frigidaire to see if a conversion kit is available. Normally, it's just an orifice replaced on the gas valve.
Feb 18, 2008 | Frigidaire GLGR341AS Gas Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
