Question about HP Pavilion dv9308nr Notebook
Describe your dv9308 motherboard no displayProblem
The laptop turns on but no diplay on screen nor via VGA
I have seen a large number of HP DV series laptops come through our service bay in the last year or so. There has been a larger than normal failure rate on these machines. This is such an issue with HP that they extended the original warranty by 12 months. I would suggest you go to the website below and check to see if your machine is one of the units under their Extended Service Plan.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
I have had very good luck talking with HP support about this issue. If it is under their warranty, they require you to ship the laptop to them for service. They pay for shipping both ways. *Backup data before you send it away*.
If, however, this machine is not under their extended warranty, I suggest you start by removing all peripherals. This includes optical drive, hard drive and RAM. Install one stick of known working RAM and try to power up system. If you get a post then there is an issue with the stick of RAM. If you get no post, try the same RAM stick in the other memory bank. If you do not get a POST then most likey there is an issue with the motherboard. At that point you look online for the cost of a replacement motherboard. It might be in your best interest to replace the laptop at that point as the cost of the motherboard and labour to replace it usually exceeds the value of the laptop.
Hope this helps
Posted on Jun 03, 2010
Pinks squares on Dell laptop screen
Try connecting to an External Monitor via the VGA Port, if Ok on a known good monitor then ONLY the Screen is faulty, if pink squares show up on the external monitor than video chip (Graphics inside the Laptop and on the Motherboard OR cable from motherboard to Screen, see how you go.
May 01, 2013 | Dell Computers & Internet
VGA: signal out of range on Dell1800FP. I see this type of card MSI PM8M3-V (7211010VPM8M3V) Motherboard installed. I know nothing, but would connect on Vga a Dell1800FP. Message : signal out of range
You need to lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution to 800x600. You mave to do this in Safe Mode by pressing F8 during boot.
Sep 30, 2012 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
This board grahpic card/diplay adapter is 1gb or 256 ??? plz detail i want to install windows mac iuse board built in vga or extra pci vga ....
your graphics socket slot is PCIE DDR2. you can use graphics card up to 1024gb.
your biult-in vga is Intel graphics 256MB
Feb 06, 2011 | ASUS P5GZ-MX Motherboard
My screen on my laptop went black.
Theres is a lot of reason associating to a black screen. First lets just assume it the screen and not the laptop. Check to see if you still see any image in the screen, you might want to do this in a lighted area. If you do, but is very dark, then your backlit light is dead and your screen needs replacement. If you don't see anything, then use a external monitor such as a computer monitor, a Tv and connect via VGA port, or HDMI if you have one or a svideo to an external souce and see if you get picture, If you do, then your Inverter is bad, or either a loose connection wiring somewhere between your comuter base and your screen. ( Because laptop tend to open and close alot) If you don't get anything via external source through your VGA, HDMi or s-vdeo, then this is something involved with your laptop. Could be from cpu, chipset, ram, or simply the motherboard itself.
Jan 28, 2011 | Computers & Internet
When I start up the my computer, the screen turns gray with a wide stripe near the center (still gray). I can see the LED lights on the computer light up, and I can hear the start-up sound that plays when...
The motherboard was not the issue given what you describe. I'm a bit puzzled as to why you replaced the motherboard, when, as you say, it works on an external. The issue here is with the inverter or backlight, mable the VGA cable although unlikely. I suggest replacing the screen in this case
Jan 12, 2011 | Compaq Presario C762NR Notebook
Black screen on acer laptop
Black screen is a number of things.
*If you`re laptop turns on but you see no display at all..does`nt even post,Then its the GPU on you`re motherboard thats faulty & will need replacing. Or
*Its you`re screen inverter which is a small circuit board located inside on the bottom of you`re LCD screen which needs replacing.Theyre cheap and not expensive.
*Do a test for example : Connect you`re laptop to a PC monitor Via VGA to VGA cable.Connect to youre laptops PC input to your monitor PC input,Then turn you`re laptop on.If it displays on you`re monitor then its the problem with your LCD laptop screen,Or the inverter needs replacing.
If theres no display on the pc monitor then its You`re motherboard onboard GPU (graphic Card) - Which you will need to replace the motherboard.
Oct 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have a VGA to RCA Component RGB Cable - 1.8M - M/M and i want to connect it to my tv so my laptop can diplay through my tv
It will not work. This cable is meant for connecting a device with RGB outputs (Blu-ray, DVD players, etc...) to a display with VGA input (such as computer monitors).
Aug 20, 2010 | RCA Computers & Internet
HI - MY ACER ASPIRE 3050'S SCREEN JIGGLES. Just started happening 2 days ago. Now sometimes the screen freezes and / or the screen gets too white for about 10 seconds then comes back to normal (but still...
First off I would do what he suggested and that will narrow your problem down straight away, If it is your screen I sugest you bring it to a repair shop and get it done proffessionaly....
Nov 17, 2009 | Acer Aspire 3050-1733 Notebook
Using a VGA cable to the 'PC in' VGA on the back of the TV, this has worked fine for multiple screens, but now there is colour distortion when watching movies via the laptop on the TV screen, help?
Can you describe the "distortion" that you refer to? Also, were there any changes to the laptop when this occurred or did this just suddenly appear?
Thanks,
Dan
Sep 12, 2008 | Televison & Video
HP Pavilion dv9308nr Notebook Logo
255 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
