Question about Sony Cyber-Shot DSC-T1 Digital Camera
All my captured images are white. The LCD shows a nice image, also the video works
  • 94 Answers
Most likely the shutter is jammed open - the shutter is not used for video or preview, which is why they work OK. Camera will need to be serviced, either shutter repaired, or more likely replaced. May be marginal, as the shutter is part of the lens unit complete! Look out for one with a damaged LCD on Ebay and make one good camera from the two if you are good with a screwdriver !
Posted on Jun 02, 2010
  • Glasto Dec 26, 2010
    Cheers, I did suspect as much, although I can hear the shutter and sort of see something going on, its almost like its just over exposing it, as you say its screw driver time :-(
How weird is this, my T1 has just developed the exact same fault after over 7yrs hard use, cant really complain its been all over the world and in some pretty harsh places.
Just seems a shame that its died.
Takes video fine, previews stuff fine, but when you go to take a pic it just takes a really over exposed picture it seems regardless of light levels ????
Posted on Jul 04, 2010
Image being Captured/Recorded is in Gray Scale (Black and White
Not knowing what capture card you have, I can only guess that you are using the componet video input to the capture card and the composite video out of the Xbox. If you are using HDMI, it could be a bad HDMI cable. This link:
https://support.xbox.com/en-US/xbox-360/console/connect-xbox-360-console-tv
might be helpful in figuring out your issue.
Nov 04, 2017 | Pinnacle Computers & Internet
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
My screen colors are corrupted such that blues are green, reds are electric blue, yellows are lavender-pink. Pictures taken since this happened are OK when transferred to PMB/other picture program. Do not...
This is a common problem on this set. This is either due to faulty CCD sensor or faulty LCD screen. Look at the previous recorded images or videos. If you see the same white lines in previous saved images or video's , it would be suggestive of LCD screen unless it is a faulty CCD sensor.
If that is LCD panel, it is not worth repair.If that is CCD sensor, then you could call up Sony to check whether CCD sensor of your model is under recall or not.
Read an old article :-
http://www.imaging-resource.com/badccds.html
If it is not under recall, try to get some good replacement or repair at low cost unless invest in new camera.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 18, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Mikomi M6607M - wont show the image/video on screen
Normal 0 Double Click on this site
http://www.free-codecs.com/download/AMCap.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multimonitoring support, zooming, aspect ratio and deinterlacing features.
AMCap is a small and effictive piece of software and definitely worth trying. Hope this will help. Bud
Jan 08, 2009 | Computers & Internet
When I turn the camera on, the image that I am shooting does not show on the LCD monitor. When I switch the camera mode to view images I have taken previously, they show up but the new images are not...
there are many point you may want to look at.
first, if the LCD does not display the picture you just capture, there is a possibility that the digital module of the device is broken and that it does not show or save the pictures you have recently captured.
if the pictures you recently captured can be viewed on a computer, there is a possibility that the connection between the LCD and the camera is loose. we canot say that tha issue is the LCD since it displays previoulsy captured image.
to work around the issue, it is best if you visit a local repair shop or a technician to have a look at the unit and have it repaired.
as per the cost, it will actually depend on the damage of the device. you may want to put a new camera as one of your options.
Aug 17, 2008 | Cameras
No image coming through on my cam
Dear Daeva,
CCD Imager of your DCR-TRV33 got defective due to unknown reason. You should go to nearest Sony service shop for replacement of faulty part.
May 25, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Powershot S1 IS trouble shooting in images of lcd monitor
Try playing back pictures you know were captured properly ( either with another properly working camera or with your camera before the problem with quality has appeared ). If the image is ok in playback but 'noisy' in capture mode then the CCD sensor is faulty /on its way out. Ask Canon if they repair CCD faults on this model free of charge.
Aug 18, 2007 | Canon PowerShot S2 IS Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
222 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
