Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Low salt indicator
Low salt indicator continues to go off. Have 18ft x 48inch round pool. Put 200 ibs in pool.
    President:
  • Intex Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Is this a new unit? 200 might be off a little if this is the first dose of salt the pool has seen. If you are using 40# bags I'd add one more. At only 7,000 or so gallons you will go from low to ideal in a hurry so do not add more than about 10 - 20 pounds at a time.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 02, 2010
Take it back. I messed with mine for a week. It was new and many postings on Internet said just clean it and it will work.I cleaned the cell twice, waiting for the salt to dissolve better and added more salt. I tried calling Intex with no answer.
Picked up new unit and within a few minutes of hooking it up, it worked.
Posted on Jun 13, 2010
Why do i continue to show low salt?
I do have the same problem every few days all I just discover is that I remove the cell tube and with the help of a long thin knife I clean the surface of the copper cell both in between and outsides. There is always dry salt on the surfaces and after the cleaning the sensor reading is in acceptable level so the chlorinator is working perfect without any 91 massage. To work it every day in order to avoid this happens very often and of course every time you hear the beap sound you have to repeat the scrutching and cleaning with the nife,
Jun 13, 2014 | Intex Automatic Salt Water System for ...
My generator first indicated low salt. I've added plenty of salt, and it still indicated low salt. I turned it off for 24 hours, and tried it again, now it has the service indicator light on,what next ?
We've found with our saltwater system (which doesn't have a service light, so not the same model as yours) that we have to add far more salt than we expect before the 'low salt' indicator goes off. It also seems to be very tempramental whenever it's been off for a while (such as over winter) & needs to run for very short bursts at first before working up to normal operating times.
Aug 02, 2013 | Intex Automatic Salt Water System for ...
I just need to know how to set the salt water system. i have an 18ft pool and have put 3 bags of salt in so far.
You don't say how deep it is. Since you say 18 foot pool, I presume it is round. AT 2 foot depth = 3817; 3 foot depth = 5726 gallons; 4 foot depth 7634; 5 foot depth is 9543. Your salt bag should tell you how much to put in referencing the gallons.
I hope this helps. Thanks for using FixYa.com
Jul 09, 2011 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
It keeps saying low salt i have an 18ft x 4ft deep circular pool and my salt water system wont clorinate
hello
there is too much for me to type please look up my name and posts about this issue
also look at my posts for low flow and green water
I promise you will learn very much about pool maitainence
Aug 08, 2010 | Intex Automatic Salt Water System for ...
Registering low salt
your pool has approximately 12,500 gallons of water
this calls for about 310 pounds of salt.
One of your problems can be the acis rain ate away at your salt content
You really need to get aalt test strip kit the kind that reads #'s not the colored strips
Get you salt to as close to 3000ppm as possible to low towards 2700 will throw off the alarm and also to high around 3800 and up will alarm also.
It is also possible to have to much salt and the unit will read 91
Get the pool to 3000ppm either by draining 20% or so and adding fresh water or adding salt which with your amount so far I am thinking you will need to lower it
Run filter only to thouroughly mix the pool for at least 24 hours before trying to generate chlorine.
In the meantime also take your electro cell and soak it in vinegar for 4-6 hours rinse well and put it back together
Jun 16, 2010 | Intex Automatic Salt Water System for ...
How much salt do i put in my pool. its 18 feet by 4 feet round. its the intex salt water system.
for the 18x48, you will add 135 pound (60 kgs) to start. When the Low Salt light comes on you add 35 pounds (15kgs)
May 22, 2010 | Intex Automatic Salt Water System for ...
My pool was clear and just great. all of a sudden the low salt light came on and stopped producing clor.so put a bag of salt in started it up and same thing says low salt , so i bought another bag put it...
Salt sensor is dirty;
Use diluted solution of muriatic acid. Contact spa store for comments/suggestions.
Brush with a mildly abrasive green fiber household cleaning pad. Contacts should be clean and bright.
WARNING Inhalation of muriatic acid vapor or contact with skin or eyes can cause serious injury or death. Wear goggles and rubber gloves, and perform cleaning in a well-ventilated area. Add acid to the water; do not add water to the acid as splashing could result.
Thoroughly rinse the Flow/Temp/Salinity Sensor with clean tap water. Replace and resume normal operation.
Sep 03, 2009 | Pool & Spa
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
374 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
