Question about Hifonics Brutus BX 1505D Car Audio Amplifier
Hifonics Taurus circuit diagra???
Hi.
I got this hifonics taurus amp which is bein a pain. protect light comes on and i've traced the problem to the final power transistors (it uses the TIP35C MOSFETS). I replaced the faulty power transistor and when I hook it up it overheats the same component. i done a pretty detailed search around the affected area but all components seem to be intact. voltage regulators and such seem to be in order and everything else is throwing me off track.
does anyone have a wiring diagram for this sort of amp, or any suggestions at all would be welcomed.
Thanx
  • andreyi Apr 09, 2008
    hey thanks for the help.
    i cannot keep the power on it longer than let's say 10 seconds or the MOSFET will overheat and die so i can only do "cold" measurements.
    the power light stays on for a few seconds at startup, after which it switches onto protect.
  • andreyi Apr 10, 2008
    you were right, the protection circuit didnt kick in but a couple of resistors from the "previous stage" started smoking (couldnt get any readings).
    The "driver" stage seems to be intact, I've also replaced BJTs along the track thinking that they might be at fault but same result. Recon it could be something in the pre-amp stage?
    and just for my comfort...you were talking about removing ONLY the affected MOSFET to take the readings ???
    Andrei
TRANSITOR CLIP REMOVER
Posted on Jun 05, 2009
  • 4,234 Answers
You need to measure the voltages at the output transistors. The previous "driver" stage may have a problem. These outputs use .6V as the bias differential. Check for DC voltage on the inputs to the transistors. These are standard designs. I'd check for DC anywhere along the signal path.
Dan
Posted on Apr 09, 2008
  • ABRsvcs Apr 09, 2008
    My original post got clipped. Remove the output transistors before you take the measurements. With no current draw, the protection circuit won't kick in.
    Dan
Protect light amp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
would definitely look at getting it repaired. These new amplifiers can't hold water to an old school Zed audio hifonics Zeus.
Jul 31, 2013 | Hifonics XX-Zeus Car Audio Amplifier
Hi iv just bought one of these and only just fitted it and the protect light is on and i have tried what the manual said but it still comes on and i live in australia and hifonics here dont have service...
G'day, I have dealt with Hifonics a fair bit here here in albury, we used a complete system for a competition car. the amps are pretty solid, but they are very sensitive to wiring. I would start by taking off one set of wires at a time and see if the protect light turns off. (make sure there is no power to the unit when removing or fitting wires) so for instance, start with the front left speaker, then if not move to the front right. etc etc.... By doing this you will be able to narrow down if and where it is shorting out. if you check all your wires and the protect light is still on, i would check where you have mounted the earth cable. make sure it is a solid connection, and that there is good metal to metal contact.
if you have any further problems, or this doesn't solve your problem phone, 0413443600, and i can walk you through further trouble shooting.
cheers nick
oh and dont forget to rate my solution
Jan 14, 2011 | Hifonics ZXI150.4 Car Amp
Amp not working
sounds like the amp is going into protection mode. maybe a sub is shorted (blown). Or, the only other possibility is the mosfet transistors on the inside of the amp are blown.
Feb 01, 2010 | Hifonics Brutus BX 1205D Car Audio...
I have a 2000 watt hifonics brutus amp ...it worked fine but 1 day it just stopped working..the power light doest light up but the hifonics led lights are still on...whats the problem?
there is a step up converter inside the amp that likes to come loose from the board. This may be your problem. Otherwise Check all the chips for burns or disconnect
Nov 13, 2009 | Hifonics Brutus BX 2005D Car Audio...
No output
Maybe you should check your remote wire!
Apr 16, 2008 | Hifonics Brutus BX 1605D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Problem!
you have a foulty amp i wtake it bk and change it
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
Hifonics 1605
have you checked Radio Shack? they have a lot of cicuit board stuff for soldering
Apr 26, 2007 | Hifonics BX1500D Car Audio Amplifier
Hifonics Brutus BX 1505D Car Audio Amplifier Logo
262 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
