Question about Toshiba Satellite M45-S331 Notebook
LAN Nic Card Seems to be bad? No longer works.
  • Toshiba Master
  • 4,924 Answers
Before getting to this conclusion ...try to see if it isnt a driver issue ..the driver can be missing if you uninstalled it by mistake ..or if a an automatic update installed a wrong driver....or if you reinstalled teh operation system and did not installed the driver for it ..
In this case download the original driver from the support site ..and run it into computer ..restart and try out the card and see if it works ..if it does all good..if not ..than you may think of getting a solution ..usually the card is on the mother board..unless you are talking about the wireless one ..the wireless card can be changed a..and so the LAN card if it is not built in the mother board ..If it is ..and you do not have space or slot to install it..just get a card on another bus.. either usb or pci ..
http://www.google.ro/search?q=usb+lan+card&hl=ro&client=firefox-a&hs=oKm&rls=org.mozilla:en-US:official&prmd=imvnsr&tbm=isch&tbo=u&source=univ&sa=X&ei=evIHT9WwGMLxsgae29yCDw&ved=0CEMQsAQ&biw=1024&bih=595
something like that ..
Posted on Jan 07, 2012
Problems with Lan Drivers for ECS 945GCT-M/1333 v3.0 Motherboard! Tried installing Lan drivers for Windows XP 32-Bit for this board and its not working or installing properly as I still can not connec
I see what you mean, ECS say's it's a Realtek device. Then Realtek driver site keeps looping the XP links. In any case, I finaly found a good link. Here is the zip link.
ftp://WebUser:r3iZ6vJI@202.134.71.21/cn/nic/Driver_XP_5800_09202012.zip
They are newer than those posted on ECS, and if this does not work you should consider buying a new PCI NIC.
Good Luck
Sep 28, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Ehternet light is out (amber), Power, wireless, DSL and internet light on (green). Desktop is wired to the 2wire. Wireless is working.
H there,
Try replacing the ethernet cable, If it does not work try reinstalling the drivers of your NIC card or LAN card. If it still does not work your NIC or LA card is busted.
Apr 18, 2011 | 2wire (2701HG-B) Wireless Router
Having lan card problems what does it affect how much does it cost to replace and fix
C521 LAN card is integrated in MB.
You can Flash the BIOS to most current and load the latest driver (Support.dell.com) see if the card works, next I'd reset BIOS defaults, and try again. If NIC will still not work, it may be damaged. Turn it off in BIOS and replace with a PCI NIC
http://cgi.ebay.com/Xinruilian-Fan-92mm-Ball-Bearing-2pin-4pin-PSU-Power-/200552830688?pt=Computing_ComputerComponents_Fans_Heatsinks_SR&hash=item2eb1e156e0
Jan 14, 2011 | Dell Dimension C521 PC Desktop
Is nic and lan card same.
NIC/LAN are the same.
Regards.
May 27, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
How to apply external lan card?
connect usb to rj45 external nic card in to the system install software from cd(one cd may be you received with external nic card)
Nov 14, 2009 | Dell OptiPlex GX280 PC Desktop
Ethernet LAN not detect
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Jun 02, 2009 | MSI 865PE Neo2-PFS Motherboard
LAN automatically disconnects while downloading and starts working only after disabling and again enabling the local area connection
With this issue it could be the Hardware / Software compatibility. The first thing to do is ensure the latest drivers are installed or the NIC. If the latest drivers are installed I would recommend replacing the NIC. They are less than $30 and they come with great drivers, and if the old NIC is onboard it would be advantageous to get it off the Motherboard. It would be best to open up the computer before you run out to get the new NIC and makesure the motherboard can support a PCI card. This card slips into the White slot that is about 3 inches long. If you have a White slot that is about 1 inch long this PCI card will not fit into it the card you will need is a PCI Express x1 NIC. The rest of the information you will need is provided by the NIC Manufacturer.
Mar 30, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
NETWORK CONNECTION ON PC
install operating again some files has been missing
Jan 23, 2009 | Broadcom BCM5721 NetXtreme Ethernet...
Lan 4pc by nic card
You can simply use or buy a router. Router will automatically network your computers without any special configuration.
Dec 17, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Nic
Hello i"am having problem with the port lan no conecting internet
he faded driver of port lan
Oct 24, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Toshiba Satellite M45-S331 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
