Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
LOOKING FOR 70474200 AND 70484200 POWER TRANS FOR PEAVEY AMP REPLACEMENT OR ORIGINAL THANKS
    New Friend:
To amp peavey modelo 1000
Posted on Nov 04, 2014
Why wont the tubes in peavey amp not warm up
This is not user servicable. Here is a link to the service locator for peavey-
Peavey com
Jun 24, 2015 | Peavey Music
Hi , i need a service manual for the peavey xr 8600 powered mixer . Not the xr 8600D . THANKS
http://music.manualsonline.com/manuals/mfg/peavey_electronics/powered_mixers_model_xr_8300_xr_8600.html
Dec 07, 2014 | Peavey Audio Players & Recorders
Peavey tnt 115 blowing fuses
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Peavey IPR 1600 amplifier will not turn on
are you the original owner, with a receipt? This amp has a 5 year warranty. If not take it to a shop, we can fix them, they are damn complicated for an amp...black magic inside.
Sep 30, 2013 | Peavey Ipr-dsp-1600 Power Amplifier - Used
How do I go about disassembling my peavey 6150+112 combo guitar amp to the point where I can replace the 12" driiver for a better one.
Most Peavey speakers you will have to just remove the grille in front of the speaker. These usually are held by Velcro like fasteners that you must carefully pry the grille out. That will give you access too the screws holding the speaker rim. Be aware that there are different sizes of speaker rims and mountings for the "same" listed size speaker. Also use the same impedance speaker as the original one or you MAY find you have less power OR blow your amp out.
Jul 30, 2011 | Peavey 6505+ 112 Combo Amp Combo
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey pv-8.5c input problem.. only one input works
HI...
I work on peaveys quite a bit. That one will need service
A guitar amp / stereo tech would do
Check the web near you for someone
rate my help if this helps
Thanks
Apr 22, 2010 | Peavey PVĀ® 2600 2-Channel Amplifier
I have a peavey Renown 400 model 212 without speakers. What speakers should I install to replace the missing ones?
THe speakers should be a good quality and rated jointly at 1.5 times the power of the amp.
Nov 15, 2009 | Audio Players & Recorders
Open Questions:
Car Audio & Video Logo
564 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
