Question about Ricoh Aficio 2027 All-In-One Laser Printer
Resetting the Tray size on a RICOH C4000 Main Printer
We are trying to print addresses and return addresses on 9 1/2 inch by 4 and a quarter envelopes.
how do i reset the tray size on the bybass tray to make sure my print comes out the way i view it from Microsoft word?
good lord help
Allie Schoen
  • 903 Answers
When you go into the print properties in Word, you can specify the paper size that will be used in the bypass tray. Depending on which driver you are using, the settings will be a little different, but there should be an option to select the input tray -- Bypass Tray -- and paper size.
As for the orientation, Word will show you a recommendation for how to place the envelope, but this recommendation isn't always right. It's a good idea to run a test envelope through and see which way the addresses print. (The envelopes should always be face down.)
Posted on Jun 05, 2010
You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
  1. Click File , and then click Print . The Print dialog box opens.
  2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
  3. Click the Paper/Quality tab.
  4. Select Envelope as the paper type.
  5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
    1. On the Paper/Quality tab, click Custom .
    2. Click in the Name text box, and then enter a name for the custom envelope size.
    3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
    4. Click in the Height text box, and then enter the height.
    5. Click Save .
  6. Click Apply to save the settings.
  7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
Dec 17, 2010 | HP LASERJET P1006 Printer
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
    Enter on the computer the follow path:
    1. enter start menu
    2. enter printers and faxes
    3. enter by right click into properties
    4. enter paper size settings
    5. set the paper size for the tray or trays and press update then apply and ok
    after thet it will work
    Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
    Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
    How to print 17 inch paper on Ricoh AP 3800 C
    You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
    Feb 13, 2009 | Ricoh Aficio 1013F Copier
    Reset Duplex Unit Correctly on Ricoh 2232C
    Hi There,
    The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
    Scott K.
    Jan 28, 2009 | Ricoh Aficio 1085 Laser Printer
    My HP Photosmart D7260 is not printing pictures
    Ok! You didn't tell me how old is the printer, what type of paper and what size you tried to print so I'll do my best to help.
    Please note:
    • The photo paper cassette cannot be installed when printing on paper loaded in the in tray.
    • The 7260 printer support 5x7 media only when printing from a computer with the printer software installed.
    Loading 5 x 7 inch paper in the HP Photosmart 7260 printer
    1. Lift the main cover of the printer, and slide the paper width guide as far to the left as it will go.
    2. Lift the Out-tray and place a stack of paper in the In-tray.
      • Load the paper with the side to be printed facing down.
      • Load paper in the portrait orientation with the shortest edge feeding into the printer.
      • Do not use too much or too little paper. It may be difficult for the printer to pick up a sheet of paper when there are only one or two sheets in the in tray.
      • Use one type and size of paper at a time. Do not mix paper types or sizes in the In-tray.
    3. Push the paper into the printer as far as it will go without bending.
    4. Lower the Out-tray.
    5. Adjust the paper width guide to fit snugly against the edge of the paper without bending the paper. The paper width guide holds the paper straight as it feeds into the printer.
    6. Close the main cover.
    Load 4 x 6 inch (10 x 15 cm) photo paper in an HP Photosmart
    Use the photo cassette to load 4 x 6 inch (10 x 15 cm) paper. To print borderless photos, use 4 x 6 inch photo paper with a 0.5 inch tab (10 x 15 cm with 1.25 cm tab). This allows the photo to print without borders on three sides and with a small border on the bottom edge that can be torn off.
    HP does not recommend printing borderless photos on plain paper. Also, remove any paper from the In tray before inserting the photo cassette into the printer.
    1. Lift the top cover of the printer and remove the photo cassette from the sheath.
    2. Place up to 15 sheets of photo paper in the photo cassette with the side to be printed facing down. For tabbed paper, insert the paper so the tabbed end goes into the cassette first.
    3. Lift the main cover.
    4. Slide the paper width guide all the way to the left.
    5. Lift the Out tray and remove any paper that is in the In tray.
    6. Line the photo cassette up with the far right edge of the In tray.
    7. Gently slide the photo cassette into the printer until it snaps into place.
    8. Lower the Out tray.
    9. Slide the paper width guide to the right until it cradles the photo cassette, then close the main cover.
    If the Out of Paper message appears on the computer and the product stops picking up or feeding paper.
    Step one: Reset the product
    1. Without turning the product off, remove the power cord from the back of the product.
    2. Wait 30 seconds and then plug the power cord into the back of the product.
    3. If the product is not already on, use the On button to turn it on.
    Step two: Check the condition of the paper and reload it
    1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
    NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
    2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
    3. Tap the stack of paper on a flat surface to align the edges.
    4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
    5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
    6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.
    If the issue persists, continue with the next step.
    Step three: Adjust the paper settings in the print driver
    The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
    1. Open a document in the program being used to print.
    2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
    4. Choose the appropriate paper size from the Size is drop-down menu.
    5. Choose the appropriate paper type from the Type is drop-down menu.
    6. Click OK and then click OK again to print the document..
    7. If the issue is not resolved, continue with the next step.
    NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened.
    Step four: Clean the rollers
    1. Turn off the product and unplug the power cord.
    2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
    3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
    NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
    4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
    5. Close the access door and plug in the power cord.
    6. Try printing again. If the issue is not resolved, continue to the next step.
    Step five: Service the product
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    If your product is less than a year old, don't worry, HP can trace the product when you provide the model and the serial number and will help you if it is in warranty. No prove of purchase required.
    Jan 09, 2009 | HP PhotoSmart 7260 InkJet Printer
    Ricoh 1035 - Tray 4
    There is a wire harness that connects the two bottom trays to the main machine. The connector might be loose or have a break in the harness. The main machine is not seeing the bottom two trays. Let me know if this helps.
    Sep 15, 2007 | Office Equipment & Supplies
    Ricoh Aficio 2027 All-In-One Laser Printer Logo
    384 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    fares
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
