Looking for instructions to adjust valves on 1987 flhtcu.... H.D.
If the engine is stock, there is no adjustment to the valves. The engine is equipped with hydraulic tappets that take up for any wear or heat expansion of the cylinders. The pushrods are non-adjustable but are of different lengths. They are color-coded as to what position they go in.
Now, if your engine has been modified and adjustable pushrods installed, they should work the same way unless they are way out of adjustment. Then, it depends on "whose" pushrods they are as not all pushrods have the same threaded ends on them. But, all is not lost.
Take one of the pushrods out of the engine and adjust the pushrod as short as it will go. Now, turn the end out until it makes the pushrod exactly 0.100" longer while counting the "flats" on the adjuster. When you install the pushrod, make sure the tappet is at it's lowest point in the bore. Put the pushrod in, don't forget the tube and the new O-rings, and adjust the pushrod out until you have zero backlash. Then adjust it out the additional number of "flats" that it took to make it exactly 0.100" longer. Lock the adjuster down. What you're doing here is the plunger of the tappet has a travel of 0.200" total and you're adjusting the pushrod so that the plunger is halfway in the middle of its travel so that it's got equal travel in both the up and down direction.
Good Luck
