Question about Acer Aspire 4315 Notebook
1995/6 Jeep Cherokee (not the Grand) air con has stopped
I have a 1995/6 Jeep Cherokee (not the Grand) with 4lit, straight 6cyl engine. The air con has stopped working. The clutch does not come in so I suspect an electrical problem. Have checked the relay. Nothing happens when you select the air con on the panel. Heater/vent fan works OK. There is a switch/electrical device on the little container with the viewing window, does this stop the system if gas is lost? What fuses are there in the circuit? Has anyone an electrical circuit for the air con, preferably the Jeep original?
What further checks do you recommend before taking it to the service centre?
Thanks for your help
  • 553 Answers
It could be an electical problem but it's more likely that one of the safety interlocks is stopping your AC from operating due to low refrigerant or low oil in the compressor.
The AC is not something to mess with if your not sure what your doing. The refrigerant can cause severe injuries on contact and over charging the system or forcing it to run if it's plugged can cause the lines to explode.
Posted on Jun 04, 2010
I have a 1995 grand cheokee larado jeep 4wd where is the egr valve for shifting located on my jeep
depends. if its the 4.0 6cyl it doesn't have an egr valve. if its the 8 cyl its in the right front of the motor
Jan 19, 2011 | 1995 Jeep Grand Cherokee
1995 jeep cherokee sport 4.0L. Oil gauge keeps sending false message ie. jumps from almost center past the highest point on the gauge. How do I fix this problem? where is the gauge sender located?
OIL PRESSURE SWITCH-I'm not sure if this is the gauge sender, though. 1995 Jeep Grand Cherokee 4WD 4.0L MFI 6cyl The Oil Pressure Switch is located: Under hood, passenger side, lower engine area, above oil pan, mounted in engine block.
Nov 01, 2010 | 1995 Jeep Cherokee
Changing a starter on 2006 jeep grand cherokee 6cyl. 4x4, how hard is it, it in a tight location, any tips
On the straight six it should not be too difficult. It is on the passenger side of the engine on the back. There are two bolts that go straight up into the housing that hold the starter on. Then you have the wires going to the starter itself. I believe there are some shims between the starter and the housing, make sure you don't lose those. It is kinda a rough job laying on the ground, but entirely possible in about 45 minutes depending on your level of patience :)
Apr 08, 2010 | 2006 Jeep Grand Cherokee
1995 jeep cherokee laredo engine number location and fuel tank capacity
the fuel tank capacity if it is a 6cyl. 4.0l then it should be about 20 gallons
Dec 28, 2009 | 1995 Jeep Grand Cherokee
I have 2001 jeep grand cherokee 6cyl need
On the top of the bellhousing. From the drivers point of view it is in the 11:00 o'clock position. The harness wraps around the back of the bellhousing and plugs in on the passenger side of the block near the oil sending unit.
Oct 25, 2009 | 2001 Jeep Grand Cherokee
What other yrear transmissions will fit in the 95 grand cherokee with the 6cyl besides 95?
42RE: The 42RE four speed automatic transmission was used in 1993.3 to 1998 Jeep Grand Cherokees with 4.0L engines. 46RH: The 46RH four speed automatic transmission was used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines.
May 29, 2009 | 1995 Jeep Grand Cherokee
Trouble code 54 on a 1995 Jeep Grand Cherokee
Carb'ed Engines:
Code 54 - Mixture Control (MC) solenoid is shorted or the ECM is faulty.
Fuel Injected Engines:
Code 54 - Camshaft (or distributor sync.) reference circuit - No camshaft position sensor signal detected during engine rotation.
Hope this helps
Mike
Jul 02, 2008 | 1995 Jeep Grand Cherokee
Acer Aspire 4315 Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
