Our Insignia IS-TV040923 has had a code entered that puts a parental block on all the channels. How do we undo this when we don't know what code was entered?
  • 10,865 Answers
You should be able to reset the TV to factory defaults via the onscreen menu system. Also, power-cycling the TV (turn it off and unplug it for several minutes) can serve to reset.
Posted on Jun 02, 2010
How do you un-block the channels
Once you've ran the auto programming and the channels you want are blocked, it's possible that someone put in a parental block on certain channels. If this is the case, only the person that put the block can tare it off because they know the code.
Mar 23, 2015 | Televison & Video
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
LTA260 digital converter box. My nephew played with it asnd entered a pass code in the parental control. Doesn't know the number. I'm locked out of most channels. How can I clear the code?
U can't in most cases,that why they called a secret passwords codes.U only can tries this by unplug the converter box and replug it back 24 hours later.Go to parental control codes mode and resetting the mode,might resetting the mode and erase the secret passwords codes,only some models of boxes could do this,ur included don't know sorry.
Aug 06, 2011 | Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Someone put parental block on half the channels on my insignia TV. How do I remove without knowing the code?
YOU NEED TO DO A FACTORY RESET, GET THE CODES FOR THE MODEL AND DO A FACTORY RESET IT WILL CLEAR OUT ALL CODES
Dec 30, 2009 | Insignia LCDTV26 26 in. Television
Turning parental control blocks off
Parental locks are put in place to stop minors from accessing usuitable programs. An adult usually selects the channels to lock out as well as categories of videos that can be played. Thesae are controlled by a code neterd by the Parent or Giuardian and cannot be subverted without knowing the code. I am tempted to say.... ask your parents for permission to unlock this. We cannot supply any information without proof of age here.
With this model also there are no secret codes listed to over ride an entered password as its not a regular brand of TV. maybe the people you bought it from ( Walmart?) may be able to contact the supplier who rebadged this unit, to help you overcome the problem
Sorry we cant be of more help for you. Please accept our apologies
Thank you for using FIXYA
Sep 25, 2009 | Prima C2012 TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Can not change parental block
Are you the admin of the computer or has your parents put a block on it? if so then there is nothing you can do apart from asking your parents to take the parental program off
Jul 23, 2009 | Microsoft Windows? Vista Home Basic...
Televison & Video Logo
Top Televison & Video Experts
