Question about Whirlpool Dishwashers
WHIRLPOOL DISHWASHER, ERROR CODE 4, ADP6000IX MODEL
  • 1 more comment
  • 1manda May 14, 2008
    we have an error 4 code it wont continue with the wash please help
  • choy01 Jun 07, 2008
    how do i fix an error 4
  • Gerard Ransom Aug 29, 2012
    Hi, I have the same problem with my dishwasher. But i have tipped it back, tipped it sideways and almost tipped it upside down to empty the water. But each time it still comes up with the ERR4 message. Has been doing the same thing for weeks. I pulled all of the sides of it and checked the float, and it moves freely up and down????
I have the solution! Had error 4 and had the repair guy come....he said its caused by too many suds...if you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completly) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone! Easy Peesy. I called whirpool about this, and why they could not tell me how to fix it is beyond me......they told me to press and hold the start button...i dont think even they know how to fix it! So...I got to do this under warranty, now hopefully you get to fix it for free and we all win. Yay!
Posted on Oct 08, 2009
  • 11 more comments
  • computerm504 Sep 27, 2010
    Thank you
  • yesseppi Nov 16, 2010
    I did this too but instead of tipping it backwards I tilted it forwards same result, mop up water that comes out with towels and hey presto no more "error 4" thanks for the information.
  • dave-at-home Dec 04, 2010
    Read the book (useless) looked on the web and tried this remedy. Apart from me skipping over the comment about needing towles and getting a wet sock (LOL) it works. No error $. Thanks buddy
  • rosswakem Jan 08, 2011
    Thanks Heaps, I did what yesseppi did and its now working. We had only recently had the machined serviced so I am so happy that this approach worked.
    Awesome
  • krage Feb 13, 2011
    Hi yes l did this and what a great help it was too. by tiupping it baclwards .l read the manual and what a waste of time that was. Unitl l came on here l found out what was going in. l was so close to taking the dishwasher back to the place that l got it from. My dishwasher is only 3 months old. l was not impressed at all.
  • wat4_03 Mar 15, 2011
    Just wanted to say a HUGE thankyou for this advice. Our dishwasher has run perfectly for 16 mths until this evening after it was packed, it came up with ERR4 and we tried everything (except for this advice) to get it working. Well you are absolutely right, my Hubby says the manual is so useless ya cant even wipe yer bum with it *lol* We tried the warranty number but they were closed. Thankfully we googled the code and landed here and now the dishwashers fixed and ready to roll again - no more ERR4 and smiles all around!! 8-)
  • seizetheday5 Aug 04, 2011
    Thank you Kazzbarr. Same problem Error 4, Perth Australia. No idea what to do and manual is hopeless. I had a wetvac so tried sucking water from door holes and drain. With all water gone, no change so pulled it out tilted it back, a couple of towels full of water came out and now its all good again 4th Aug 2011.
  • hi-tonemusic Aug 05, 2011
    OMG thank you very much this realy does work so greatful
    OMG thank you very much worked great and save $ when i rang assistant line just wanted to send tech and have to wait for them to fix when it only had taken me 10mins thank you for you advice
  • cathydearing Nov 15, 2011
    Thank you, just saved myself a call out fee. Dishwasher fixed after following your suggestion. Woo Hooo!
  • robert_poste
    robert_poste Feb 14, 2013
    Have the same error sounds like.your answer would. Be suitable however it seems my dishwasher is connected to the supply and can't til backwards any other hele please?
  • Cath Porter Sep 23, 2013
    Thanks heaps. This worked a treat and saved me the cost of a call out as well.
  • Ahmed Halwagy
    Ahmed Halwagy Oct 30, 2016
    Thanks alot , it solved my issue
I just did what the girl above said, Tip it on its back slightly with towels around the base at the back to soak up all the water that drains out and PRESTO after about 3 mins tilted backwards water had stopped dripping out and i pressed POWER and YESSSSS no ERROR 4. Great Advice Thanks!
Posted on Oct 09, 2009
The ERR4 error code indicates overflow detected. This can be for a bunch of reasons. For us it was because the dishes we put into the dishwasher had too much food on them. The filter clogged, and possibly food ended up going down the little over flow sensor tubes.
Assuming the dishwasher has no water inside it (i.e. while running ERR4 it has pumped it'self out), the fix. 1. Turn off the dishwasher. 2. Get some towels. 3. Empty your dishwasher (just slide the trays out with the dishes still in them). 4. Clean the filter and any extra bit floating around the in the dishwasher. 5. In the bottom of the machine neat the front edge there are two small tubes. These are almost hidden by the bottom of the door. 6. Pour water down each of these tubes. 7. Close the door and turn on the machine to empty the water out. 8. Tip the machine back for a few minutes (this is where the towels come in). 9. Open the machine and get a pen body (straw, pen body, 1/4 inch tubing etc will be fine). Put the pen body into tube into one of the tubes mentioned in step 5 and blow. Repeat this for the other tube. This should help clear anything stuck in these tubes. 10. That should be it....
Posted on Jul 23, 2011
I had the same problem, I just turned off the inlet hose at the tap and unscrewed it. This seemed to release the pressure that built up. Turned the on/off button on and pressed start, and it's now working fine so far.
Posted on Aug 11, 2010
Yeah it worked after 1 minute for me thanks : ) Just wished I knew what the problem was 3 hours earlier
Posted on Apr 05, 2010
Well done Kazbarr worked a treat I am still waiting for Whirlpool to get back to me with an answer!!!
Posted on Mar 03, 2010
I have the same problem but i leave it and it fixes itself yay
Posted on Sep 04, 2008
    New Friend:
This didn't work for us. :-( error 4 keeps happening. It won't drain and when we tipped it, no water came out. Can only assume there's a blockage somewhere. Any suggestions?
Posted on Jun 18, 2015
  • Steve Scott
    Steve Scott Jan 10, 2016
    If the above doesnt work. There a clear tube from base of tray to a switch. It requires an air tight seal. Get two small hose clamps and place around tube and tighten. Should work properly now
Yep, I had the same problem - error 4 just tipped it forwards after pulling it out of the cavity unplugging everything. It worked!
Posted on Jul 06, 2014
    New Friend:
Hi all, I had the same problem, error code 4, and after reading all these treads was convinced it was the float sticking. WRONG. After pulling off the side cover (Remove top first with two screws on back, then kick plate, two screws underneath and the trick here is that there are two plastic lugs inline with the feet that need pulling up, I broke one, then remove the LHS panel by undoing the 10-15 screws) I checked the float and this all seemed right. I checked all hose connections and none of them appeared to be leaking. I then ran the machine with the sides off. BE CAREFUL as everything is now to be considered as LIVE. When it started filling I noticed water was coming out of the center of the machine and on closer inspection found it was actually on the inside washing area that was the problem. And it was all my fault. When I had previously removed the bottom jet arm to clean out all the little holes I must have bumped the crew cap that goes through the floor as it was 1/4 of a turn loose and letting water down to the motor area, hence setting off the float and activating the Error 4. 1/4 of a turn on a plastic cap would have saved me 1.5hrs of stuffing around. So please check that first.
Posted on Oct 28, 2013
  • Mick
    Mick Oct 28, 2013
    first.
Kids helped with the dishes, then the dishwasher says ERROR 4. Frustrated turned to internet for solution, pulled it out, turned it off and tipped it over a bit, water on the floor. Cleaned up the whole thing turned it on and hey presto, fixed. Thankyou thankyou.
Posted on Jul 08, 2013
3 Suggested Answers
SOURCE:
SOURCE: my dishwasher is coming up
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Posted on Aug 13, 2010
SOURCE: WHIRLPOOL DISHWASHER ADP6000IX
your not alone. i to have this error 4 and so do hundreds of others.it means low water level even like mine your water level probably isnt low.what happened to mine was the sensor got a layer of fat and oil scum buildup on it and couldnt detect the water level so i cleaned it and worked good for another month. then same problem.solution- dishwasher had an "accidental short due to water leak" wich insurance covered and bought me a new dishwasher (fisher and pikel) now no more problem
Posted on Aug 20, 2008
What's error 2 in whirlpool adp6000ix dishwasher
ERROR 2 = Longer Drain Time
Possible cause = The installation position of the drain pipe too high or the drain pump faulty
Jul 26, 2018 | Dishwashers
Model ADP6000WH/ADP6000IX. What is error 2?
if this is a model that flashes the clean light in blinking code for faults , then your not properly reading the flashing light , if it repeats the two - two flash rate this is an indication that its lost its communication between its internal circuit boards (most times this is a logic board problem ) but it can be the other ones as well or ive even seen a wet cable do this as well , if the flash rate is 1 flash - two flash this is an indication that there is stuck key on the keyboard (or a cable problem too )
but the Number one problem I see with dishwashers is there's water(or had been) where it should not be !! water in the wrong spot causes all sort of gremlins to show up and it doesn't take much just one drop and its chaos
Apr 13, 2016 | Whirlpool Dishwashers
My whirlpool slimline dishwasher is showing E4 and trips mains when switched on
frothing or water level high. Possible cause using tablets instead of powder or liquid. Take a look at this post.
Whirlpool ADP6000IX dishwasher Kitchen Home
Jan 17, 2015 | Whirlpool Dishwashers
Our whirlpool dishwasher make ADP6000WH/ADP6000IX runs for the first few minutes of each cycle the just kind of pauses and will not finish the cycle
Check your FLOAT... When it stops, Open the Door and see the Water LEVEL.
If the Water LEVEL is normal, then you have a problem with your Circuit Board
Apr 09, 2013 | Dishwashers
Whirlpool dishwasher ADP6000IX error3
see page 6 on this user manual for description of error 3.
Sep 21, 2012 | Whirlpool Dishwashers
Whirlpool adp6000ix not cleaning properly
I would suggest getting a de calcifying agent and putting the washer through several cycles. Sounds like the dump valve may be getting plugged up.
Sep 06, 2012 | Whirlpool Dishwashers
My dishwasher is coming up with a error 4. my dishwasher is a whirlpool ADP6000WH/ADP6000IX please help
Aug 05, 2010 | Whirlpool Dishwashers
My dishwasher is saying 'error 4' on the panel and it is beeping, can't find the instruction manual to work out what the problem is. It's a whirlpool
Error Code 4
Error Code 4 means: Overfilled - Too much inlet water. I found by disconnecting the water supply (after turning it off) then reconnecting it fixed it http://kitchen.manualsonline.com/ex/thread/view/idThread/231213
Sep 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Problem with whirlpool dishwasher ADP6000IX stuck on drain mode has err4 on it which means water inlet problem has sencer that changers to pump mode now is stuck on pump
Hi I had the same problem with a whirlpool adp6000ix. Although it looked fine from the inside, the base was full of water. I managed to fix the problem by pulling the dishwasher out and then tilting it gently to the side. All of the hidden water in the base poured out which cleared err4. It is now working fine. Tip: Make sure you have a couple of towels spread around before you tilt it. Good luck!
Aug 07, 2008 | Dishwashers
Jul 30, 2008 | Dishwashers
Dishwashers Logo
16,620 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
