Question about Yamaha R-V902 Receiver
Receiver Power shuts off
When I was playing my CD player it was shutting off, so thought maybe it was the CD player since it was plugged into to the Receiver. However I took out the CD player and used a seperate outlet. Once I powered up the CD player will play briefly but then the Receiver just clicks and shut down. Any idea if it's a fuse or just wire etc...
    President:
  • Yamaha Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
When I plug my Onkyo receiver in it turns on and off on its own in intrevals of about one second. Is this a bad power supply or something else?
follow these steps:
*disconnect everything from the unit (treat it as if you just got it out of the box) no speaker wires no cables.
* turn on the unit and max the volume (w/o anything connected)
*if the unit shuts off during step 2 you need to send it in for service (go to onkyousa.com for the nearest service center)
*if it didn't shut off during step 2 you need to play the tuner and connect one speaker at a time.
EXAMPLE: connect your left speaker and then play the FM and then max the volume for about 2 seconds then turn it down.
if you were successful in maxing out the volume on the left speaker continue with the other speakers until you isolate w/c speaker is causing the issue. if your gonna ask why the FM...its because its a direct playing source but you can still use a cd player or a tape deck to try it out.
take note: if your receiver shuts down on a speaker that you have connected make sure to have that speaker checked or better yet replace it.
May 03, 2009 | Onkyo TX-8511 Receiver
Power does not stay on.
check and replace caps in the power supply as they maybe leaking causing the voltages thought the unit to be unstable.
Apr 15, 2008 | Hitachi DV-P745U DVD Player
Receiver shuts off when trying to play a dvd in the dvd player.
Just a hunch - what's drawing power from the two convenience outlets on the back of the receiver. They're only rated for 120watts, that is, nothing like a TV.
I doubt this has anything to do with the source you're playing (unless you have it cranked to "11"). If I understand you correctly you said turning the TV on and off causes the problem. There's a clue.
Apr 07, 2009 | Denon AVR-1803 Receiver
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
Receiver randomly shuts off during play
This is the "Protect" mode. It is either a bad speaker, or not good ventilation, or a channel going out in the receiver. Please provide more details about the problem so I can help you better. How long is it playing before it shuts off, does it shut off even if the volume is low? Disconnect the speakers form the receiver and then turn it on and let it play without speakers, if it still shuts off then the problem is not the speakers. More information is needed to better diagnose this problem.
Jan 07, 2009 | Audio Players & Recorders
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
Jun 11, 2008 | Technics SA-DX1040 Receiver
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Problem with cd playing
You have not described the fault or machine type clearly, is it just a CD player, what make and model, shuts down,? CD play stops or machine goes into standby mode or what ?
If stops playing or maybe going into s/by mode, check the cable that connects the laser to the cct board.
Capital98
Dec 14, 2007 | Audio Players & Recorders
Yamaha R-V902 Receiver Logo
137 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
