Question about Veritas Backup Exec 10 for Windows Servers Advanced Disk-based Backup Option for PC
I get a ready no idle devices are available when trying to run a backup. Any advice or suggestions would be greatly appreciated
Hazards spontaneously turned on and won't turn-off in 2001 Saab 9-3
try going to a saab dealer and ask if a merchanic could give a bit of free advice an where the onstar cpu is.
martyn
Apr 08, 2013 | 2001 Saab 9-3
2003 F250 Super Duty diesel 6.0 needs multiple tries to start.
It is a Ford. Replace the fuel pump and check the fuel lines for leaks including any filters.
Nov 01, 2017 | 2003 Ford F250 Super Duty Crew Cab
1997 buick lesabre idles high (about 2900-3000) when started stone cold. Lately, you have to feather the throttle pedal to make it stay running. Let it run for five minutes, shut it off, restart, and it...
Check the electronic temp control by the thermostat outlet, it looks like a water temp sw. , but it sends a signal to the computer to tell it what the temp outside is and add fuel to the engine based on temp. If it is bad it messes up the idle.
Mar 31, 2017 | Buick LeSabre Cars & Trucks
My wireless antenna is in and the thing says does not exist
You need to make sure the drivers are installed for that device. If you talking about an external wireless card, I believe it came with an installation disc. Run the disc and your wireless card will be detected by your computer and is ready to use.
**comments, suggestion and rating will be greatly appreciated
thanks!
Sep 15, 2010 | Computers & Internet
Can't get my HP j4680 to Fax or Scan. I have spent many hours today trying to set up thi HP All in One. I finally have the printer working on my wireless network. When I tried to set up the fax, I got...
Hi Jelind
This is the first thing to do to clear all the printer history. Go to the bottom of the thread.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Unable-to-install-HP8500-drivers/m-p/17...
This is the second thing to do after you try to install and it tells you a section is missing from INF. There is probably a missing registery value for imaging device. It fixed my 309a issues. Great hardware-support a bit lacking.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035977&cc=us&dlc=en&lc=en&jumpid=reg_R1002_US...
sharpinjr
Apr 18, 2010 | HP LaserJet P3005 Printer
Idling hunts by around 300RPM when car is hot. (working temp.)
try cleaning the throttle body first then if that dont work you will need to replce the iac motor wich is located on the bottom of the throttle body your car is hunting for the correct idle position and either the sensor inside the iac motor is dirty or it is bad
May 12, 2009 | 2003 Mitsubishi Outlander
"the device is not ready"
The device not being ready is a sign that windows cannot finish installing it or that the device is beyond simple software recovery.
You can try rerunning recuva in safe mode, which will disable some of the performance circuitry that may be interfering.
Also make sure the directory you're trying to save the recovered files to is NOT on the same drive. If it is and the drive is failing it will not work, not to mention you never want to recover to the same drive as it runs the risk of overwriting the files you're trying to salvage with some if the same files.
If safe mode and re-aiming the recovery folder doesn't work then you likely need to send it to a pro with some higher end gear. Try Armor-IT Data Recovery, they're listed in the FixYa database if these suggestions don't work.
Chris
May 06, 2009 | Toshiba MK 3018GAS (MK3018GAS) 30 GB Hard...
Saw idles great but as soon as I stop throttle in log it stalls
The wife bought me a Wild Thing for Christmas at my asking. Went to use it on Saturday and it would not run for squat...I had to make my own Carb adjusting tool because they have changed the idle mixture screws to make it more painful to do...backout the L for Low Idle screw about 1/4 of a turn. Once you get it to idle and can actually slow the idle down enough so it runs correctly you can then fine tune the mixture at an idle. Then full throttle it and see if it runs ok there. If it does, your ready to go..If not, back it out, counterclockwise 1/8 to a 1/4 of a turn and see how well it runs. Basically from what I can tell, they did a really bad job of setting the carb at the factory!
Jan 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Rpm's fluctuate when trying to idle and eventually dies
check for vacumn leaks, hoses, and intake. check idle air control valve for proper operation, if you have check engine light run codes by shorting diagnotic terminal and turn ignition to run. Should flash any codes in system.
Dec 14, 2008 | 1993 Geo Storm
Java not detected
Try this. Go to Start, Control Panel. Click on Java. At the bottom of the dialog box where it says Temporary Internet Files click on Settings and delete the temporary files. Restart your browser.
Jun 22, 2008 | Computers & Internet
Veritas Backup Exec 10 for Windows Servers Advanced Disk-based Backup Option for PC Logo
1,149 people viewed this question
Top Veritas Computers & Internet Experts
Jax Planet
Jax Planet
Mike
purushottam aher
Level 1 Expert
Are you a Veritas Computer and Internet Expert? Answer questions, earn points and help others
