Question about GE Advantium 120 Convection/Microwave Oven
GE Advantium PSB2201NSS Technical Service Guide
Model Number: PSB2201NSS
Brand: GE Advantium
Age: 13 months
PSB2201NSS GE Advantium 240V. 13 months. Went dead (2nd time now, first time was replaced as it happened within three weeks of installation. Read on Servicetechhelp.com that it is probably the Oven Cavity TCO. After seaching online, I have the part number WB21x10046. I know where to buy it but can't determine how to access it even with the GE schematic. Is there a GE Consumer Service Training Technical Service Guide that I can download for this model? Thanks.
MicrowaveSvc
  • 9098 Answers
SOURCE: Does not work after speedcooking bacon.
Most repair warranties are only 30-90 days, but you might consider asking the servicer if they'll cover it. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your actual model number (like SCA1000DBB03, not Advantium 120) here: http://tinyurl.com/gv383 That part is the thermal cutout (TCO) or thermal fuse. It's reference number 1430 on the first diagram listed there.
Posted on May 08, 2007
SOURCE: GE Advantium 120
no they do not. I just replaced one of these they aren't hard but it would be very difficult to do without takeing it down. due to the price of these I strongly recomend you call your local appliance service
Posted on May 20, 2008
  • 111 Answers
SOURCE: replacing the cavity light on the g e advantiom zsc 1001
The bulb is a halogen type and there is a service kit that slighty changes the way it is mounted. It is not easy to get to from the top unless you do it for a living. Call GE Factory Service for the kit and a nice smiling technician to come out and take care of it. It may still be under warranty. 1-800-432-2737
Posted on Dec 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a dead GE Advantium 120 Microwave in my RV.
This heat could have come from excess current draw due to a failing part, such as the magnetron, or an improper voltage level at the outlet. It should measure 105-125VAC.
A loose connection can also result in heat and melting.
I would recommend replacing the section of wire that's melted. You need to make a good solid connection with proper wire nuts and solid crimped connectors.
If you think the TCO may have been stressed, it should be replaced, too.
I would also check the fuse holder by seeing if you can twirl the fuse with your bare fingers while it's in the holder. If so, then it is too loose and the holder must be replaced.
You cannot just squeeze it tighter with pliers, because metal fatigue will make it go loose again, possibly resulting in a melted fuse.
Lastly, I would replace the primary interlock (top door switch). See http://www.microwavedisplay.com/doorsw.txt.
Then make sure that no one opens the door while the oven is cooking unless it is specifically called for in the cooking cycle. Opening the door while it is cooking leads to premature switch failure and heat / melting of the switches connectors and wiring.
You can find the full service manual online here.
Yours may have the revised circuit. You can see the "mini-manual" for that version here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Posted on Jan 10, 2010
  • 8909 Answers
SOURCE: My advantium just quit.
I don't see why not. If you can make good the connections and use ceramic couplings, due to the heat, plastic will melt and cause a hazzard.
Posted on Oct 28, 2010
Is there something that is safe for me to spray/apply that will help loosen a door switch that sticks on a GE Advantium 120 Oven?
No, I would replace the switch. See this page.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 10, 2017 | GE Microwave Ovens
Is it possible for a GE Advantium (PSB2201) to turn itself on? I awoke this morning to a strange sound in my kitchen. The thing was running full blast and hotter than hell! It does not seem to have
Yes, it is possible. And it's dangerous. If it isn't under warranty, or you can't have it repaired. I suggest unplugging it when it's not in use.
May 02, 2013 | Microwave Ovens
G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
Bill,
I have the same unit. It just happened to me. DId you find a resolution?
I was using it on the oven mode and it just stopped working. It's completely dead.
Thanks
Bob
Apr 11, 2010 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Interior Light GE Advantium replacement
Yes, that's right. Very common, standard 10W halogen available about anywhere. GE's # is WB36X10163 or WB36X10177.
Jul 18, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium oven has no power
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE Advantium SCA2000B Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
May 07, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
391 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
