Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
I have an old Progressive vacuum cleaner that says "Hepa Filter" and "Whisper Belt". Not sure what the model # is. The problem is that the vacuum part itself (the part that touches the floor and rolls over) has ejected its filter that we can see through the little window- it just came out under the rollers under the device... we cannot see how to re-insert this piece of filter which looks like a kind of round, flat grey foam/fabric and clearly goes inside- (top of the part that touches the floor and that we can see from above)== how to replace??
  • Kenmore Master
  • 17,970 Answers
Check this procedure:
  1. Unplug the appliance that you will be changing the filter in.
  2. Open the filter cover. On most appliances, the location of the HEPA filter will be clearly marked as it is a major selling point of the appliance. If your HEPA filter is not clearly marked, check the manual that came with your appliance to find its location.
  3. Rip your paper bag so that you can open it flat. It should be large enough when open to completely cover the HEPA filter. Hold the paper bag to the HEPA filter (so you do not touch it with your hands) and gently pry the HEPA filter from its holder with a flat-head screwdriver. The idea is that any dust or mold that comes free will stick to the paper bag and not your skin.
  4. Pull the old HEPA filter out while wrapping the paper bag around it. Discard it in the trash outside the building.
  5. Unwrap your new HEPA filter and press it into the holder in the appliance. Make sure the arrows imprinted on the casing of your HEPA filter face into the appliance. Replace the cover and you are done.
Good luck.
Posted on Jun 02, 2010
Get the belt to turn in Progressive Whisper belt
Make sure the roller is not jamed with carpet threds , remove bottom cover and clean dust balls and obstructions out see if ti resolves problem make sure it's unplugged when checking and install complete before applying power!
Feb 21, 2015 | Kenmore 25614 / 25615 Progressive Bagged...
How do i remove a motor from a sears canister vacuum
Most of those machines are clipped together... go to youtube... punching the make and repair... should be a video there to show you
Dec 02, 2014 | Kenmore 2 Progressive EF 2 Pleated Vacuum...
Canister powerhead brush does not seem to spin when the carpet level adjustment is on any level other than "high". Could it be something as simple as needing a new belt and is there a...
The belt is worn/stretched to the point that it cannot take the load on low level setting due to more resistance against the carpet and there is also no signifagant difference between the two belts except for expecting a longer belt life from the whisper belt. While it is apart make sure there is no hair or carpet strands in the rollers and around the belt pulleys
Jan 18, 2011 | Kenmore 25512/ 25513 Progressive Canister...
How to install the back hepa filter on canister vacuum cleaner. We are not sure which direction the air flows and therefore which way the arrows should point. Should the arrows point into the vacuum...
The arrows in this case should point out of the machine. not into the machine. This is because you want the black rubber seal to seal on the machine and force the air through the filter.
Good luck.
Mark
Nov 10, 2010 | Kenmore 25512/ 25513 Progressive Canister...
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
HEPA FILTER REPLACEMENT
Looks like there are is an 2 indentations on the back, these are tabs, push them in and push the cover up, it should come off.
Jan 29, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
88 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
