Question about Panasonic CY-VHD9500U Car DVD Player
Remote Sensor not working. I have tested the remote and it's working fine, but need to replace the sensor. Need help finding and replacing. Any ideas of places to order parts?
    Sergeant:
  • 293 Answers
Hi and thank you for using fixya:
I do not like being negative but is very hard to find just the sensor alone. Try places like craiglist and ebay where you find the most uncommon things. On how to replace it just open it up un-weld the sensor and just weld the new one on.
Good luck
Posted on Jun 02, 2010
T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
Nov 28, 2011 | Televison & Video
Toshiba 43" 43H70 Projection TV - Remote Sensor not working
Here is your manual
Someone else with same problem
Seems like they you may have sensor problem, remove board and check solder connections and/or replace IR sensor bad pic below of toshiba sensor board below.
7151e29.jpg It should be hidden behind the smokey plastic cover in the right corner of set,
Dec 30, 2007 | Toshiba 43H70 43" Rear Projection...
My remote will not work the tv anymore
there are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Yours sincerely
Elect_Comp.
May 12, 2011 | Televison & Video
Can i replace a coby dvd 224 remote
Yes you can replace the coby dvd 224 remote with a new one, all you need to do is to get a replacement remote that looks exactly the same as your old one. You can try out that of a friend before you go ahead in replacing it with a new one. Be sure that the problem is not that the battery of the remote is weak and needs replacement or the sensor on the device you use the remote for and the remotes sensor is not bad before you can replace the remote.
Test the sensor by opening the device to check if the pin that is holding the sensor light is not rusty, if it is, then it is the light you are to replace, check the same on the remote to see if the problem is from the remote, then you replace the sensor light which is the infra red light on both the remote and the device itself.
Hope this information helped you. Thank you for using fixya.
Jan 18, 2011 | Coby Lands Phones
Model 42pfl3603d/f7 tv stopped receiving signal from remote.. remote IS working.. side controls on tv work it just does not process the signal from the remote.. unplugging does not help.. any ideas?
If you find the remote sensor eye located on the front of the TV, you are there!!! There is a small sensor board and a TV tech will have to replace this for you. There is usually a capacitor, resistor or diode that will need replaced. I replaced the remote sensor board. Thanks for asking and show a few hands of support.
Jan 11, 2011 | Philips Televison & Video
The remote stopped working
If your remote stops working all of a sudden, first thing you need to check on is the remotes battery, replace the batteries and try to test it again, if it works, it means that simply solved the problem and if it does not, then it means the problem is from another source.
Try to change channels from the television by pushing the channel buttons that mostly used to be by the side of the television, to see if it changes channels, if that does, then you need to find out if the remote sensor on the television is not rusty, for that you will have to unscrew the television open and access the remote sensor.
You will have to try out another similar remote on the television to see if it works, if that works, then it means the remote is bad and need to be replaced with a new one. And if it does not work, then it means loosening the television is the next thing to do to check if the remote sensor in the television is bad.
Unplug the television, then unscrew it apart, be sure to allow television rest for some time to allow the high voltage dissipate, after that you start the work on the television, then you disassemble it to see if the pins holding the remote sensor are not rusted, once you find them rusty and broken off the board, you can either replace the remote sensor or resolder it properly back on the television.
After doing that, reverse the process to reassemble the television back and plug it, then test the remote and it will work once again.
Take care and good luck
Dec 18, 2010 | LG 50PC3D 50 in. Plasma Television
Remote Control doesn't work
It may be the sensor in remote or tv. The only way to tell is to get an orgional replacement from manuafacture, or get a universal. Much cheaper and easier than testing or replacing sensor.
Jun 03, 2009 | Mitsubishi WD-Y57 57" Projection HDTV
Remote won't work.
this would be the IR sensor on the tv that recieves the signal from the remote , but testing of the sensor and components in the circuit should be done.
there will be an Identification number on the sensor and you will have to get that ID and you can either google it or post it here and I will help you find the sensor
Mar 19, 2009 | Toshiba 50A61 50" Rear Projection...
Panasonic CY-VHD9500U Car DVD Player Logo
134 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
