Question about Sony Audio Players & Recorders
My protection light is green but i get know sound.
  • Sony Master
  • 5,167 Answers
If no channels are heard, it might not be the power amp section to blame, in any case the protect mode would only activate if an overload was present, caused by faulty speakers or wiring often!
Having said that the power amp could be to blame, but only if the amp used a single IC to output stereo channels.
Apart from that what you are looking for is something that is common to both channels, perhaps a pre-amp IC?
Hope that narrows the culprit down for you.
Posted on Jun 04, 2010
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
Red light on, tripping the fuse box
Need to know if it's tripping a breaker or an RCD.
sound like an earth fault and tripping the protection.
you need a qualified professional.
Mar 27, 2010 | Freezers
Power light turns from green to red protect mode and then there is no sound coming from my speakers
there are 2 reasons for it to be going into protect mode 1 is heat 2 is the load on it. if it is going into protect mode soon after it starts there is a problem with the speaker. if it is after it has been on for a while it is that the amp itself is overheating. hope this answers your question
Apr 27, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp works when beaten
It sounds like you have a broken connection in the amplifier. The first thing to check is the fuse. Sometimes the contacts become weak on the fuse holder and the connection becomes intermittent. Any other troubleshooting would require opening up the amp. Any repairs would require resoldering the broken connection.
Sep 22, 2008 | Jensen XA2250 Car Audio Amplifier
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
Amp green then red light then nothing problem please help
It sounds like the output transistors have failed. To eliminate other possible problems, read through the following page.
Troubleshooting - Amp in Protect Mode
Aug 05, 2008 | SPL Dynamics Z2X-1600 Car Audio Amplifier
Directed audio 800a amp the protection light keeps blinking
1. Check your grounds. (including grounds for your stereo)
2. Check to make sure the power cable you connected to your car battery is properly connected, and not coming into contact with anything metal.
3. Make sure you are using proper fuses.
4. Check your connection from your stereo to your amp, and your amp to your subs.
Jul 18, 2008 | Earthquake Sound XTREME 900W.5 Car Audio...
KICKER KX350.4 sound fading in and out
Does the amp continue to go into protection if you disconnect the speaker wires from the speaker terminals?
Apr 14, 2008 | Kicker 04KX350.4 Car Audio Amplifier
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
