Question about Lakewood 101 Floor / Box Fan
Is a replacement grill for the Lakewood 101NS Floor/Box Fan available?
Boggsj
  • 20 Answers
SOURCE: Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
Posted on May 23, 2007
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
Posted on Jun 03, 2007
SOURCE: need help with fixing my lakewood floor fan.
Throw away the fan and buy a new one.
Posted on Aug 05, 2008
Benimur
  • 6966 Answers
SOURCE: Broken grill Panels
Pls try here and look for an authorized parts distributor near you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
konzzz
  • 255 Answers
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
Posted on May 28, 2009
Broken grill Panels
Aug 30, 2008 | Lakewood 200I Floor / Box Fan
How do I clean the Lakewood Tower Fan LWTF-42/RC-DLX. How can I open it to clean the blades
Open the grills and use a long stem tipped with cloth dipped in kerosene to lightly clean the dust. Then use a similar arrangement of dry cloth wound on it to wipe clean the moist dirt. Repeat the process and you will have a clean blade. Use a jet air blower to assist you , use face mask and do it out in the open.
Helpful ?
Aug 20, 2010 | Lakewood 007 Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
Need help with fixing my lakewood floor fan.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
How to remove fan cover
Hi, although mine is currently not working I was able to take the cover off by loosening the six screws that hold the front grill on - the screw heads are visible around the edge of the outer ring.
Good Luck
Keith
PS - there are then four (I think) which fasten the back grill to the motor
Jun 26, 2008 | Lakewood HV 18-c Floor / Box Fan
Need help troublshooting floor fan problem
This problem is caused by worn brushes, these are probably not replacable. You could replace the motor but you will have more money tied up in that then replacing the fan.
Jun 24, 2008 | Lakewood HV 18-c Floor / Box Fan
Need feet for 20" box fan
you can purchase the feet at lasko.com go to there parts dept. i think i paid 2.00 plus s+h.
Oct 16, 2007 | Lakewood 200I Floor / Box Fan
May 27, 2007 | Lakewood 200I Floor / Box Fan
May 23, 2007 | Lakewood 200I Floor / Box Fan
Lakewood 101 Floor / Box Fan Logo
128 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
