Question about LG Vu CU920 Cellular Phone
Phone won't charge or hold a charge - tried 3 different chargers and a new battery. Cleaned all connection points with alcohol. LG Vue
    President:
  • 1,561 Answers
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
Posted on Jun 02, 2010
My Lg is not keeping charge, and I bought a new Battery and it still wont charge or keep charge. Please Advise.
A charging problem could be due to a bad battery, corrosion on the battery contacts (you can clean them with rubbing alcohol) a bad charger or the charger plug on the phone. I would try replacing the charger and checking the connects.
Jan 13, 2016 | LG Cell Phones
Galaxy Note slow charge. Holds battery well though.
try this ..get a qtip and dip in 99% rubbing alcohol. not too wet. just damp. clean contacts on the charger port. use a magnifying glass and light to check if its clean. let it dry for 20 mins. it will also help if you have airplane mode on but its optional. use oem charger and cable or ipad charger works fine with samsung cable. hope it helps
Jun 10, 2017 | Samsung SGH-i717 Galaxy Note HD LTE 16GB...
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
I've had an LG Chocolate 3 for about 3 yrs and love it but all of the sudden it wouldn't hold a charge. When charging it flashes "charging" on the screen but it really wasn't. I had...
i think there is virus infection to your phone in this case Please Visit your Nearest LG Service center they will do the needful for you & this is the only way to solve your problem.
Kindly Visit LG Service center
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | LG CHOCOLATE VX8500 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
Battery is required to charge......got this message on my LG Muziq just out of the blue, now what can I do?
First I would try going to the sprint store and try a different battery. If it works fine with that, buy it. If you get the same error with a new battery, try a different charger. If you still get the same error with a new battery and charger, disassemble the back of the phone with a small phillips screwdriver and remove the main board. Once the board is out, clean it with rubbing alcohol (preferrably 91% rubbing alcohol) and a toothbrush, especially around the charging port and the battery terminals. If it has gotten wet, you should see the corrosion when you open it up.
Be very careful unplugging the flex connections. A small tear or bent pin could cause costly damage to the phone.
Aug 21, 2008 | LG Cell Phones
Charging lg kg 220 phone
Almost certainly liquid damage to the lower part of the phone!
Depending on your skills, removing the back cover (the bottom lifts after removing the four screws and then you need to twist and tug the top to get the back off) and clean the bottom 1/4 of the phone using a toothbrush soaked in isopropyl alcohol. Then dry completely with hot air, a hair dryer will suffice.
10 out 10 non-charging KG-220 seem here in the last six months were all fixed using this method!
The classic indication is when plugging the charger into the switch on phone, the handset turns off.
Dec 11, 2007 | LG KG220 Cellular Phone
Motorola E815 - Battery Charger
I had the same problem but for some reason was able to use one of those Energizer battery chargers but no others!! I took it to Verizon and they cleaned the pins. Try using a toothbrush to clean it. That worked for awile then stopped. I took it to them againa and since it was still under warranty, they gave me a new one!
Aug 21, 2007 | Motorola Mobility E815
How do i resolve the error: use genuine battery. power off
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
Nov 08, 2006 | LG U8150
LG Vu CU920 Cellular Phone Logo
598 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
