Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The lights flickered in the house and all electronics went off
Everything came back on ok except the Television. Now I push on the on button and it then will blink several times but wont come on.
  • RCA Master
  • 8,617 Answers
Replace the deflection board. You can get a replacement deflection board from www.tvrepairworld.com
Posted on Jun 03, 2010
Have 3 or 4 Maestro dimmers in house. After a storm it seems that they flicker every now and then at lower settings.Other lights in the house seem fine. Do they flicker every now and then normally. Check...
No, they're not supposed to be flickering, regardless of the light-level. I can't think of why a power outage would cause the lights to flicker all of a sudden. My first suggestion, check the lamps - make sure they're incandescent or line-voltage halogen lamps. If they're CFL or LED, then flicker (particularly at low-end) isn't just possible - it's likely. Other sources of flicker - sometimes the power companies install new metering equipment that throws some jitter on the line that cause issues - not much you can do about that unfortunately. My primary suggestion is to call tech support at 1-800-523-9466. It's free, they're available 24/7, and can probably offer more suggestions than what's available through doing this over a web-site.
Apr 14, 2011 | Lutron ELECTRONICS MAW-600H-LA SMART...
We had a brief storm come through and all the electronics flickered or went off but all came back on except the 52 inch RCA HDTV rear progector television. Now when I go and manually push the button on the...
The fuse(s) in the set may have blown open to protect from a surge. If you're confident with being able to open your set, you can locate the fuse(s) and hold them up to a light. If the filament inside is broken (and especially if there's soot or brown-ish residue), then it's blown and must be replaced. DO NOT bypass a fuse or replace it with another one that's a different value. It'll say on the metal rings what it's supposed to be, so make sure to use that specific value.
Jun 03, 2010 | RCA HD52W56 52" Rear Projection HDTV
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
Lights on push button 4 wheel drive out
have the electronic transfer case checked the switch is stuck or broken
Jun 25, 2009 | 2001 Chevrolet Silverado 1500
Have an hitachi 53uwx10ba red light on front is on but no tv
on some TVs, the lights do not turn off so that is not that big of a deal.  If you want to make sure, unplug the TV and then push and hold the power button for about 30 sec.  Then plug the TV back in and that should fix the light if it is stuck. (Pushing the power button wile unplugged will reset the system default!)
Nov 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Won't power up
contact the customer care.
Oct 04, 2008 | Sanyo DP32746 32 in. LCD Television
Philips television dead, want turn on.
as you are a electronics engineer please psoceed as follows you have checked fuse & it is ok it clearly means that there is no SHORT CIRCUIT. 1 check power supply output. if it not ok then check components connected to swithing ckt. 2 if it is ok check horizontal section. remamber that it is not a major problem.
Sep 25, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
