Question about Weber Genesis E-310 Gas Grill
My grill is hissing and the nozzle is screwed on tight. Is their a washer piece that is supposed to be included with this set?
  • 494 Answers
If you are smelling gas, do not try lighting anything until you figure out what is leaking. Spray soapy water on everything to pinpoint the hiss sound. The tank valve should have a rubber gasket inside it that seals against your black plastic female hose end fitting when you hook it up. It will not seal if it is missing. If that is the problem, take the tank back where you filled it or exchanged it. Douglas
Posted on Jun 02, 2010
How do I replace a windshield washer nozzle on my 2005 equinox (front)
In a nutshell, the process to replace the washer nozzles is,
1. Remove Wiper Arms
2. Remove the Air Inlet Grill
3. Release the nozzles from the inside of the Air Inlet Grill assembly
4. Install in reverse order
The wiper arms are each held in place with a single nut. Try to resist the temptation to pry the arm away from the shaft, gentle wiggling should suffice to get them free once the nuts are off.
When installing the arms that should have been removed while the wipers were in their parked position, line the end of the wiper to the little dots in the bottom blackout strip of the glass. Use a flashlight to see those dots under the glass. After replacing the nuts, torque the nuts to 21 foot pounds.
The Passenger side of the Air Inlet Grill is the cover access for the cabin air filter. If you've never changed that filter before, this would be a good time. It's probably pretty bad after some 10 years. There are 5 reusable plastic fasteners holding that cover down. There are 2 more on the far drivers side of the Air Inlet Grill. Carefully pry the center tab up to release tension on the fastener, then pull the whole fastener out. If the fastener comes apart, it's easy to reassemble in the center backed out position in preparation for reassembly.
The Washer Nozzles have compress to release clips accessed from inside the Air Inlet Grill assembly. Attempting to remove these from the outside will only damage the Air Inlet Grill. Replace and snap the new nozzle in place, before starting the reassembly steps.
Best of luck. I think a person with a reasonably talented set of hands should be able to do all of this, but don't rush.
Mar 09, 2015 | 2005 Chevrolet Equinox
How to connect side burner correctly?
slide the tube onto the rear of the knob and then set into place and put nut on. as long as the tube fits over the brass nipple, it will work
Jun 16, 2012 | Weber Genesis Silver B Grill
Clogged pressure washer nozzle
Some of those adjustable nozzles are made with a removable orifice. If you look close, it is basically a small set-screw with a hole in it (for the spray orifice). I am not sure what size you need, but they are always metric, "allen" style "screw/orifice". If this is the case, go anywhere that sells sowing supplies and buy a long, slender needle. This is the only thing I've found that is really strong and small enough. Use the needle to dig or force the blockage out.
If your spray nozzle is not made with a removable orifice, you just have to take the nozzle off of the lance and use your needle to dig or push the blockage out. Generally, you have to push (and dig) and it has to come out the way it came in (and that is why you have to take the nozzle off the lance). Be sure to rinse the nozzle out good why you get the orifice unblocked -- or it will just block it again.
While you are working on it, you should be worried about where any debris came from to block the nozzle in the first place. The system is supposed to be closed. If you are running it without a screened inlet or a water filter of some kind, you better fix that. If a piece of debris the right size goes into the system, it can get hung in a poppet valve which is a little harder to work on -- AND -- can damage various parts of the pump.
I hope this is helpful to you. If yes, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Briggs & Stratton Briggs Stratton...
Windshield wiper moter went out i need to change it out. how do i change it?
  1. Disconnect the negative battery cable.
  2. Remove both wiper arm and blade assemblies.
  3. Remove the cowl grille attaching screws and lift the cowl grille slightly.
  4. Disconnect the washer nozzle hose and remove the cowl grille assembly.
  5. Remove the wiper linkage clip from the motor output arm.
  6. Disconnect the wiper motor's wiring connector.
  7. Remove the wiper motor's three attaching screws and remove the motor. To install:
  8. Install the motor and attach the three attaching screws. Tighten to 60-85 inch lbs.
  9. Connect wiper motor's wiring connector.
  10. Install wiper linkage clip to the motor's output arm.
  11. Connect the washer nozzle hose and install the cowl assembly and attaching screws.
  12. Install both wiper arm assemblies.
  13. Connect the negative battery cable.
Installing the wiper arm connecting clip.
Feb 25, 2011 | 1992 Ford F250
Where is the wiper motor on my 1999 GMC Yukon?
Windshield Wiper Motor
Removal & Installation
To Remove:
  1. Remove wiper arms.
  2. Remove weatherstrip from cowl.
  3. Remove two cowl vent grille panel screws.
  4. Remove windshield nozzles and hoses.
  5. Remove three cowl vent grille panels.
  6. Disconnect windshield wiper motor electrical connector.
    NOTE: Do not remove crank arm from windshield wiper motor.
  7. Loosen nuts that attach the drive link brackets to the crank arm.
  8. Remove wiper motor crank arm brackets.
  9. Remove three bolts and windshield wiper motor from vehicle.
To Install:
  1. Install windshield wiper motor and three bolts.
    • Torque to: 62 in lbs. (7 Nm)
  2. With right side linkage closest to the windshield wiper motor, install drive
    link brackets to wiper motor crank arm.
    • Torque nuts to: 44 in lbs. (5 Nm)
  3. Connect electrical connector.
  4. Install nozzles and windshield washer hoses to cowl vent grille.
  5. Install three cowl vent grille panels and screws to vehicle.
  6. Install weatherstrip to cowl.
  7. Install wiper arms.
Oct 30, 2010 | 1999 GMC Yukon
I have a weber genesis grill. just refilled the tank and connected it. this afternoon my wife smelled gas near the unlit grill. There was also an intermittent hissing sound. could the heat of day 90 plus...
seems like I can always smell a little gas on a freshly filled tank until I use it down a little bit. Also there is a bleed off screw on the valve of the tank Make sure it is tightly closed
Aug 09, 2010 | Weber Genesis Silver B Grill
The Blazer micro torch does not ignite (no hissing sound for the gas either) and we did fill it with butane? Any suggestions - have had it for awhile - maybe it needs new flint? or whatever ignites it....
Hi. Get a piece of very fine wire, hardware store is a good source, and run it into the nozzle. Chances are that the nozzle is clogged. Once it is hissing again it will ignite unless you also need a new flint. J.
Jul 08, 2010 | Omega Blazer Self - Igniting Butane Micro...
Weber Q 120--propane leak when removing canister
i would say that might be faulty mine just screws together and unscrews nothing falls out
Apr 20, 2010 | Weber Baby Q Grill
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Broken Part
I called Fox-International and ordered a new Grill Plate Handle for my GRP99.
$14.95 includes Shipping.
Dave in Ohio
Mar 25, 2008 | George Foreman GRP99 Indoor Grill
Weber Genesis E-310 Gas Grill Logo
607 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
