Wf320 Thanks for the answer. I've tested the heater element and it is isolated from earth and reads 30 ohms between terminals. Could it be the stat thats at fault?
    Problem Solver:
  • 10 Answers
I would go for a insulation test then at the stage that you gave in your description it sound like itis the heater because it does cut in at that time noffie........
Posted on Apr 09, 2008
How to check the heating elements in GE harmony dryer
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Oct 29, 2014 | Dryers
Heater not working on model wml 904 p/g/a/k
This would be a Hotpoint/Indesit appliance I am guessing from the model number, the heaters are easy to replace. isolate the appliance, removed the back plate on the cabinet and the heater is located on the back of the drum below the pulley, it will have 5 wires going to it, live, neutral, earth and 2 smaller wires which will be to the temperature sensor. To test the heater use a multimeter and it a good heater should read approx. 30 ohms
Apr 12, 2014 | Hotpoint Washing Machines
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    NType your problem for a solution...need to access the heater element to test
    not to familier with your washer but you have to take the back off and then you should see the heater at the bottom of the drum with wires on take the wires off make sure you mark them get a muti meter set it on ohms test across the two terminals you should get a reading if not the heater has gone and try it from one terminal to earth on cabinet you should not get a reading if you do its faulty
    Dec 01, 2011 | Miele Novotronic Premier 500 Front Load...
    I have a GE DWSR405EBWW Electric dryer. It stays hot after completeing cycle (coils still energized). I opened the unit and coil doesn't look visually broken or grounded. 3 thermostats, 1 is a 4...
    The way to check the element for being grounded is UNPLUG THE DRYER remove the wires to the element and check eact terminal individually to the heater housing if any ohms at all from each terminal to the heater housing the element is grounded.
    As far as the t-stats 2 of them should have zero ohms and the one w/4 terminals the two larger outer ones should be zero ohms the two smaller inner ones will have somewhere between 100-1000 ohms what the smaller one is a heater inside of the t-stat so when set to delicate the t-stat heater heats the t-stat so it trips sooner on the low heat setting since it(t-stat) gets hot sooner
    Aug 06, 2011 | Dryers
    Auto defrost is not working. How does the system work and how can I diagnose what part is at fault; heating element, sensor, control unit, etc? I believe it has an electronic control unit and not a...
    there are 3 parts of the defrost system ill walk you through how to test them
    1) defrost heater..isolate wires to the heater and use multimeter set on ohms/continunity and check for continunity and appx. 30 or so ohms on the heater,
    if it has no contininity its defective
    2) defrost thormostat(clipped onto top of evaperator coil) to test it it must be cold so its best to test it when frost is built up on evap.coil,isolate the wires to it and check for contunity with ZERO ohms resistiance if it does not have contintunity (when cold) it is the problem
    3) defrost timer...unplug it and see the 3 terminals grouped together (disregard the one off by it self ) place meter lead on CENTER of the 3 grouped together and on one of the outside one and their should be be continunity with zero ohms resistiance,if not continunity switch lead to other outside terminal and ALWAYS on center on and check for continunity,if has contintunity turn the little different colored peice till it clicks and check for contintunity on center terminal and the outside one that didnt have have continunity before turning it till it clicked.if one side has continunity before clicking and other does side does not after clicking it the timer is bad
    electronic deforst control is very hard for the layman to check and must be assumed to be bad if both defrost heater and defrost t-stat are good
    Good luck and godspeed
    please give 4 thumbs up if this helps
    Gene
    Jul 27, 2011 | Refrigerators
    Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
    in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
    Jul 20, 2011 | Kenmore Dryers
    Test procedure for elements and thermostat
    Remove upper and lower access panels
    in upper access, use voltage tester to test voltage of on the uppermost terminals above the red reset button. should be ~220V between terminals (110 to ground)
    If not: breaker off or bad,
    If 220V proceed:
    Test the two terminals immediately below this reset button should be 220V
    If not: reset tripped or bad
    If 220V present, proceed.
    Turn off breaker to heater.
    Use ohm meter or continuity tester.
    test resistance across upper element terminals -should be 10 to15 ohms
    check between each terminal and ground -should be open circuit .
    If not replace element
    Repeat for lower element.
    test across lower element thermostat should be no resistance when stat turned up so it clicks on.
    (To test that lower stat turns off, allow tank to heat up completely before conducting this test) Turn sta temp down so it clicks off then test across stat terminals -should be open circuit
    The upper thermostat is a 3 way switch
    The simplest way to test it is to turn the power back on turn the upper stat all the way up so it clicks on and use voltage tester across the UPPER element terminals, should be ~220V
    Now turn the upper stat down so it clicks off- check upper element should be 0 V between upper element terminals -(Caution ! terminals will still be live 110V to ground)
    The upper stat has now sent power to lower stat.
    Turn lower stat up so it clicks on, check Voltage across lower element -should be ~220V turn lower stat down so clicks off, should be 0 V across lower element terminals.
    NOTE If tank is completely cold the upper stat will not switch off and wont send power to lower stat.
    If lower tank is cold lower stat may not click off even when turned down.
    normal stat setting is 125 to 130
    The hotter you you set the stat, the faster your tank corrodes.
    Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    I have a ck20 hobart deep fryer that when plugged in and turned on, lights both lights,but does not heat.I checked both fuses with an ohm meter and they appear to be fine.Can you tell me what the...
    The element will show infinite resistence if defective. Overload switch.....Do you mean High Limit T/Stat? Use your ohm meter across terminals- should read closed circuit...0 ohms. If not, push red reset button...if clicks once, is now reset and contactors will close and unit will heat. If always clicks, replace limit t/stat Like wise, check themostat--should click once for heat demand and check cicuit same as limit t/stat. May have wire burned off terminal connector at element.
    Mar 30, 2009 | Hobart 1HF50D Deep Fryer
    Hotpoint ultima tumble drier condenser has F 10 error code
    Error code F10 means common feed of heater or thermostat open circuit.
    You need to test the thermostats and the heater element for continuity.
    You need a multimeter to do this, assuming you know how to use a meter,then set it on the ohms range for continuity, remove one wire from each stat, and test with meter across terminals of stats,
    You should get FSD if stats are o/k.
    If you don't, then you need to replace both stats, even if only one is faulty.
    It is unlikely to be the element that is faulty, as they rarely fail.
    Plz rate my solution.
    Thanks
    Jan 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
