Question about Kenmore 75101 Wall/Window Air Conditioner
Does the outside vent need to open or closed for
Does the outside vent need to open or closed for max cold air?
  • Kenmore Master
  • 43,501 Answers
Close the vent to get the most cooling...
heatman101
Posted on Jun 03, 2010
2003 ford expedition i just got it a week ago and the front heat works great but the back vents only blow cold air. How do i fix this?
With the car parked and engine idling, turn the ventilation control between windshield defroster and "open air ducts" to front and rear vents. Listen to pinpoint where the valves are that open and closes the air ducts. It sounds like the air duct to rear vents are blocked, and the cold air in rear air duct is coming from "outside ventilation." The air vent to allow hot air to the rear vent is stuck in "open ventilation" mode, like when you're driving in spring or summer months.
Nov 29, 2013 | Cars & Trucks
I have a 2008 ford explorer. If A/C is on MAX. Some sort of dustry powder comes with air blow. I feel like washing my face every half hour during driving. I makes me totally uncomfortable. My family a
with a very efficient a/c on max there will be cold air from the vents ( like a mist) I suspect thet if you go down from max ther will not be a problem. What I suspect you have is air almost at the snow forming temp
Jan 10, 2013 | Ford Cars & Trucks
My furnace isn't heating my house. I was wondering if this was because there is a vent from my cold air duct to the outside thus drawing to much cold air into the system. Should this vent be closed in...
If this vent is connected to the return air duct line back to your furnace I would close it off. The only reason that I can see for having a vent to the outside is if you need more combustion air supply.Thank you.
Feb 21, 2011 | Heating & Cooling
Emerson quiet kool wall air conditioner. Should vent be open to remove humidity?
No - opening the vent will allow unconditioned outside air into the space and add to the humidity load.
Think of it like your car's A/C - when you put the controls to "Max A/C" the system recycles just the air inside the car and doesn't use any outside air. When the control is set to normal A/C, some outside (fresh) air is brought in.
The same thing is true for a window A/C unit. Keeping the vent closed will help the unit de-humidify and cool the air more quickly.
Jul 12, 2010 | Emerson Quiet Kool 12NW46K Air Conditioner
Freezer cold, fridge isnt. Vent issue. Please Help before thaw!
Is there any ice/snow whatsoever built-up on the rear panel of the freezer ????(very important to know this).
If so, you have a problem with the frost free part of your fridge,causing it to ice-up,
and blocking the air flow to the fridge section.
Repost, and we should be able to go from there.
Wigo.
Mar 04, 2010 | KitchenAid Refrigerators
A/c cold on onside not the other.
sounds like a cracked vacuum line... or a bad vacuum control box getting the settings confused check there first.. (hot air from outside is being forced in on the one side because one vent is open, cold on other then when on normal when both outside vents should be open 2 arent and one is)
Jul 10, 2009 | 2003 Ford Explorer
1995 lincoln town car heater
the door opening & closing on Max a/c is the inside/outside air intake door.
The temp blend door is the one you are concernd about. It says you have to remove instrument panel for access. ouch!!!
A/C Electronic Door Actuator Motor
The A/C electronic door actuator motor (19E616) is located on top of the A/C evaporator core housing assembly.
  • Its function is to move the A/C air temperature control door on command from the control assembly.
  • The A/C electronic door actuator motor contains a reversible electric motor and a potentiometer. The potentiometer wiper is connected to the actuator output shaft and moves with the output shaft to indicate the position of the A/C air temperature control door.
  • Battery voltage is applied to the ends of the potentiometer. The voltage available at the wiper indicates the position of the potentiometer. The actuator wiper voltage is sent to the control module and matched with the wiper voltage of the module potentiometer. The printed circuit board then drives the actuator motor in the direction necessary to make the actuator wiper voltage agree with the control module wiper voltage.
Dec 27, 2008 | 1995 Lincoln Town Car
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
96 Ford Explorer AC problem
change your Heater Control Valve. I've seen a quite a few of them do this and it's almost always the valve
Jul 14, 2008 | 1996 Ford Explorer
Cold air from outside coming in house through vent
Sounds like your damper (flap) outside is working, and that's probably the first thing to check. Wind may be also pulling the damper open from time to time. Hopefully the pipe fitting is sealed, and the pipe is insulated anywhere it runs through any unheated portion of the house. Some amount of cold air getting in will be unavoidable. The best bet next might be to look over the two pages in the installation instructions that deal with outside venting. If you don't have the installation instructions, you can get a copy here: http://www.geappliances.com/service_and_support/literature/ Then if you don't notice any obvious problems with the installation, it may be time to contact the installer for their two cents.
Feb 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 75101 Wall/Window Air Conditioner Logo
234 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
