Question about AEG Lavamat 72640 Front Load Washer
AEG LAVAMAT 75520 door light doesn't switch to green
This washing machine has a front loader and display. The door lock goes into a plastic socket and the door is properly locked. The door light does not switch to green, however, and it doesn't start. All other buttons seem to work.
When the door is locked a small plastic box slides in position inside the socket. There seems to be two positions for the box. I am able to manually slide it back and forth. The box does not switch positions when I open the door. The box is connected to feathers on the device the socket and the box is a part of.
The machine isn't that old but it has been in storage for a couple of years.
Any ideas would be appreciated.
    Master:
  • AEG Master
  • 480 Answers
AEG LAVAMAT 75520 door light doesn't switch to gre - untitled-rq2y3fnvghvfrpvxa33jafnd-5-1.jpg After turn and choose cycle by program switch, press the Start / Pause button otherwise the program will not start.
If you did everything right then the "Cd" should appear on the display, which means door lock failure.
green = The door can be opened
av = The door can not be opened at the moment
red = Door is open
Dado
Posted on Apr 29, 2017
  • 1294 Answers
SOURCE: AEG Lavamat w1450 electronic.
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
SOURCE: Door locked
Rather than taking the top off the machine and fiddling around to find the catch as guest suggests, I got it to open with some strong string. I took a fairly long piece and threaded it into the groove where the door joins the metal front of the machine, on the catch side of the door. Then pull both ends of the string very hard to the left (you may want to wear gloves to protect your hands). Pull hard and move the string up and down until the door opens. Worked for me.
Posted on Feb 15, 2008
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
VOTIT
  • 2071 Answers
SOURCE: Washing machine door lock problem
Just try to check the door latch device. Be sure that the latch is not bound or sticking in any way .This problem with a lot of machines and it almost always was the door lock latch assembly. It has a switch inside it that pauses or stops the cycle if the door is not closed properly, when this switch malfunctions then it will pause or stop the cycle repeatedly; just from the small movement of the wash cycle. The door will actually be shut all the way and the lock may be on. You must replaced this switch so it works normal again..
Just click for the spare parts site link;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
  • 326 Answers
SOURCE: I need cogs for my aeg lavamat where i CAN GET IT?
you can get it at  www.repairclinic.com
Posted on May 06, 2009
Aeg lavamat w1450 will not light up..... power is on
many times it turns out to be the door switch has failed .
Jul 12, 2016 | AEG Washing Machines
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
I have a AEG oko-lavamat 75520 update. It stopped and the code C9 showes on the display. What does the code mean, and is this something I can fix my selfe?
Hi Mrs Willems from retired Englishman in SW France,
According to my list, AEG Lavamat 8*** Series Onwards C9 stands for 'tacho fault' (monitoring the motor speed) requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 16, 2011 | Washing Machines
AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts to flash. Door indicator light then goes from...
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
Jan 07, 2011 | AEG Lavamat 12710 Front Load Washer /...
WILL NOT GO
can be a faulty heater or motor with an earth fault. you need a man with insulation tester to test for earth faults.
Jul 08, 2010 | AEG Lavamat 72640 Front Load Washer
40C cycle stopped with 12 mins on display - now nothing works
Press "end of cycle" & wait for 2 minutes then try the door, do not force the door........................ If problem persists go to your model above & click on your model number & look for solutions....should find something.
Jan 12, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
Try:
Nov 12, 2007 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 72620 door does not open
It seems that your problem is with the lid switch and it should be replaced. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Good luck!
Sep 05, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
197 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
