Question about Xerox XA7-172i 17" LCD Monitor
I have a xerox monitoer flat screen,it cuts off after about 2ominutes on my pc then i have to switch the monitor off then put it back on after another 2ominutes then it comes on again but will cut off again after bout 20 minutes use ,
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 03, 2010
MoNITO MESSAGE "Out of Range"
You need to lower your PC video resolution to the native resolution of this monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 27, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen is broken. How do I switch to an alternate
plug the vga cable from the external monito to the (usualy blue female port on the laptop) and depending on the laptop you would press FN key + Fx( which fx being the f key with the two monitors icon below the F) that will switch it to the external
Oct 07, 2009 | Sony Computers & Internet
Once the PC is booted up the monito screen goes dark
try another monitor to isolate if it is the monitor, if it is the LCD, the back light may be going out
Jul 07, 2009 | Computers & Internet
Computer monitor becomes distorted after boot up.
Download and install the correct driver for the monito as well as the deiver for your video card, if the video is onboard, you may need the motherboard and AGP driver as well.
You will probably need to boot in Safemode to do this.
Good Luck.
Feb 10, 2009 | HP Computers & Internet
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Blank screen for 15-20 minutes at startup
I have a Xerox XA7-19i. It has the same problem as described by many others - intermittent fault with the display that manifests as a white screen when the monitor is first switched on. After a few trys of switching on and off, the monitor works fine until left off for a few hours. Recently, the problem deteriorated to no light from the panel, and a flashing blue power light.
I HAVE SUCCESSFULLY REPAIRED MY MONITOR:
I opened up my monitor and removed the power supply board.
I de-soldered every electrolytic capacitor, and replaced them with new capacitors of the same uF and voltage rating.
I put the monitor back together again and switched it on - it worked perfectly!
Yes - these monitors have been built using sub-standard / under-rated electrolytic capacitors. After two years of use, the power supply board was unable to supply enough power to the logic board and backlight, causing the above-mentioned problems.
The repair cost me ~ GBP 15 (USD $30). It is not a difficult fix, but one only to be attempted if you have electronics knowledge. Careful, kids! you'd be playing with the power supply of a mains AC electronic device. That stuff can kill.
But - I saved myself (and the environment) from having to throw out a monitor and buy a new one. If you have a faulty xerox monitor and are getting no love from Xerox customer support, find an electronics geek and ask them to replace the electrolytic capacitors on the power supply board. (but be careful to get the right kind of capacitors, and to get the capacitor polarity correct. If you have any doubt as to you ability to do this, don't bother trying!).
Sep 02, 2007 | Xerox XG-91D 19" LCD Monitor
19" Xerox flat panel monitor
always try with another monitor,before do nothing else. this reveal if the problem is the monitor. could be a cable problem( cutted inside),could be a backlight problem (it have a flourescent tube and a inverter that makes it "shine" ,or a supply problem what means it don't even work.these tree case are for the repairman.
Jul 09, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XA7-172i 17" LCD Monitor Logo
143 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
