Question about Dewalt Dc212 18 Volt Sds Plus Rotary Hammer Drill
Dewalt 24 volt drill sds
Got a 24volt sds drill about 5years old problem is it makes the battery get hot and start to smoke when you put it in any ideas whats wronge
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
Posted on May 24, 2009
  • 1026 Answers
SOURCE: dewalt sds drill dramatically slowed down
tight bearing maybe
Posted on Nov 02, 2012
My dewalt dc223 has a normal chuck on it but no sds chuck.. will this stop the hammer or is it broken?
If someone replaced the chuck the hammer part likely failed and it's a normal drill now, the hammer function would destroy a regular chuck.
May 10, 2014 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
I have a dewalt 24 volt sds drill when attach the fully charged battery to the body nothing happens when i remove the battery from the body it starts to smoke
So what is your question. It sounds like you have a bad battery so try it on another tool. If it works then the drill is not working or assembled properly if the same thing happens then you have ruled put the drill and there is a proplem with the battery
Mar 03, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Dewalt 24volt dw005,... as soon as i put a battery into the body of machine the battery starts to smoke ,the drill still works but to me seem's like its got a short circuit .i've took handle o
To be sure it's the switch, check for continuity between the positive and negative contacts at the terminal block, where the battery connects to the tool, with the switch off. There should not be any continuity there, if there is the battery will have a constant draw (short circuit) on it which will cause it to overheat and smoke if left on long enough. The switch is replaceable, it's part number 487136-00 but shop internet stores, the switch is around $75 +s/h.
Feb 26, 2012 | Drills
I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE WITH OUT LOAD IS 51 VOLT.AND WITH LOAD IS 15 VOLT.THE BAATERIES BECOME VERY HOT WHILE CHARGING
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
May 18, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
When i use the drill it smokes real bad where the batt. connects
you have a short in your drill motor. I would not recommend using it as it is possible for the battery to explode.
DeWalt is probably the best made drill motor. I would look to sending it back to the factory for repairs. Run the internet for DeWalt and get a phone # to call them. You never know, this may be a problem the factory may fix for free.
Nov 21, 2008 | Dewalt 18 Volt Compact Drill Kit
Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Dewalt Dc212 18 Volt Sds Plus Rotary Hammer Drill Logo
103 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
