Question about Abacus Concepts Abacus Smart Watch 2006 Modern Metal
The watch does not receive a signal, unless I attach a long (60 inch) wire as an extra antenna. (too weird to wear that way). Could this be a physical problem with the band?
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
Will not receive signal
If you are in the US or Canada the signal is coming from Fort-Collins, Colorado. If you are too far or there are atmospheric perturbations along the way, at the times the watch is in automatic receive , the watch may not receive a strong enough signal to synchronize itself with the atomic clock signal. The watch is not always able to do so.
Read the manual where it is suggested that you put the watch on a window sill, the dial facing outward with 12 at the bottom. Do not move the watch when it is trying to receive a signal. If you have a signal strength meter, orient the watch so that the signal is as high as possible.
Sep 30, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Need extra band links
Watches and cufflinks are two main accessories wear by a man around his wrist.
Extra links can be ordered with your credit card by calling Service Center.
Aug 14, 2013 | Timex T2H351 Watch for Women
Seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Apr 29, 2010 | Swiss Army Wenger Commando 70725 Wrist...
G-Shock Atomic Solar watch - ERR in atomic time keeping
The watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
I have a Movado Eliro Men's Black Dial Steel Watch which I received as a gift about three years ago. It stops running whenever I wear it. If I take it off and let it sit for a few hours...it starts...
It sounds like some portion of the circuitry has 'gone thermal.' As a test, set the watch in a sunny place and allow it to get warm; if it again stops, then the quartz oscillator section has become sensitive to minor increases in temperature.
This is not a DIY situation since the major part of the circuit will be on one IC and because of size and proprietary nature of it, it will require a pro to remove and replace it.
As a better watch, it might be worth repairing and I would check the manufacturer's website to see if they offer repairs; some better companies will do this free to protect their reputation.
You can start here:
Movado Service page
Sep 22, 2009 | Movado Eliro 0605377 Wrist Watch
How do i put on the wave ceptor ?
This depends on what you mean by your question.
To adjust the size of the band, if you look on the inside of the links (the side that goes against your wrist), you will find that at each link joint, there is a spring-pin (like the traditional pins for attaching bands to watches) which can be easily removed.  Remove the necessary number of links to size the band to your wrist.
To put the watch on your wrist, merely position it as desired, and, close the clasp by grasping the outer buckle with your fingers, placing your thumb against the mid-segment, and squeezing the two together. Then, move that assemblage upwards toward your wrist.  Move your thumb out of the way as it approaches closure and push it together until the outer buckle clasp clicks into place around the stud on the inner segment.
If you are asking how to get the watch to receive the time from WWVB, this will happen automatically once per day (three attempts per day until one is successful).  If you want to manually trigger an attempt, this can be accomplished by holding the "RECEIVE" button for a few seconds until the watch beeps and the display reads "RC!".  It will then attempt to receive the signal from WWVB for several minutes and calibrate if successful.
You can identify whether the last synchronization attempt was successful or not by the display in the lower right corner while the time is displayed.  It will show an antenna and three bar-graph segments if it was successful, or, be blank if it was unsuccessful.
If you mean something else by "put on the waveceptor", I'm afraid I don't understand your question.
Mar 10, 2009 | Casio Atomic-Solar MTG900 Watch
I recently purchased a stauer watch model E-244S on e-bay and did not receive any instruction manual, thought i was getting a quality watch, but really know nothing about the brand or its quality. It is a...
they cost about $60. they are cheaply made throw away dress watches. you didn't get ripped off. you just wasted your money on cheap chineese garbage, you are not alone.
wear the watch, throw it away when it stops or you don't like it anymore.
Apr 25, 2017 | Bulova Watch
My Casio model 2735 atomic watch needs a new battery. I cannot find a local jeweler to fix it. Please tell me where I can send it. Thanks George Sills gls860@sbcglobal.net
I can fix your CASIO ,,problem is that im here in philippines. Your casio watch is not need to set it can receive time calibrated signal transmitted from ,Fort Collins,Colorado reception signal ,,thats very cool watch ,here in our place we have battery for that ..or you can go the web site of CASIO and you can order what you want..
Jun 19, 2008 | Casio Watches
Abacus Concepts Abacus Smart Watch 2006 Modern Metal Logo
121 people viewed this question
Top Abacus Concepts Watches Experts
Jimmy Accardi
Are you an Abacus Concepts Watch Expert? Answer questions, earn points and help others
