Question about Weather King 12AJA4801AH Air Conditioner
My weather king furnace and ac will not kick on at all is there a reset button
  • Weather King Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
LOCATION OF 62-24164-01 IGNITOR ON WEATHER KING FURNACE
Who knows? You gotta post a video of your furnace so we can see what you got. Here is the sequence of operation of a late model furnace. they all basically work the same way. They have a draft inducer fan that causes a vacuum in a small hose leading to the pressure switch. If the board reads negative pressure it know the draft motor is working and pulling a draft it then cause the ignitor to kick in and after a minute opens the gas valve. It wait a sec to verify flame with the flame sensor and then if that flame is there it keeps burning and after 30 more seconds the fan kicks in.
Most of the time if the ignitor ain't workin it is either bad or a limit has tripped due to some sort of overheat problem like birdnest or cobwebs and such.
https://www.youtube.com/watch?feature=player_embedded&v=NjOsXv4Z-lg
Oct 05, 2012 | FACTORY AC PARTS Furnace Spark Ignitor...
My furnace smells musty, and is kicking out mold from the vent nearest the unit. What do I do?
Turn the furnace OFF and locate the drip pan. It sounds like it is clogged or has been clogged and needs cleaning. Also, I would be interested to know, how you determined that it is mold being kicked out from the vent nearest the unit?
Hope this helped and thanks for choosing FixYa.
Jul 26, 2011 | Weather King Heating & Cooling
Weather King 10aja1801
The answer is yes however you will want to change the indoor coil in the furnace also.
You would look for a 1.5 ton matched set.
Jul 19, 2010 | Weather King 10AJA1801AH Air Conditioner
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
I'm trying to figure out if our Weather King system has a heat pump... how do I tell?
Your indoor furnace is weather king? If you have a a/c unit outside, it could be a heat pump, but you have to provide the model number on it.. If you do have a unit outside, when you call for heat does the outdoor unit kick on?
Dec 03, 2008 | Heating & Cooling
Weather king ac not working at all
see if there is a switch at the furnace that may be off.check the doors as well for tightness.If that doesnt do it,you may need a pro.
Aug 05, 2008 | Weather King Heating & Cooling
Weather King 12AJB60a01 - Noisy Clang at Startup like hitting metal lockers
Sounds like the compresser is going out on the unit the noise is internal the winding would not have anything to do with that noise maybe valves going out
May 23, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 12AJA4801AH Air Conditioner Logo
494 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
