Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
Strange clacking/humming noise coming from back of refrigerator
Sounds like it could be coming from the fan, lasts for 10-20 minutes a time, once every six or eight hours. just started two days ago. also, a back panel on the refrigerator seems warmer than the rest of it.
thanks
  • Samsung Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorstrange clacking/humming noise coming from back of - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
I hear a sharp snap then a loud humming noise which sounds electrical. If I turn the refrigerator switch off, then on, the humming stops. Otherwise, it lasts 10 to 15 minutes. Its getting louder.
DID U CHECK UR EVAPORATOR FAN AND LISTEN IF THE NOISE IS COMING FROM IT? COULD BE BROKEN OR IMPEEDED IMPELLER HITTING SOMETHING ON START UP THEN GOING INTO A HUM?
May 20, 2015 | Sharp Refrigerators
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Humming noise from refrigerator 9top).
This is likely due to a bad freezer fan motor. The main back panel in the freezer can usually be removed to check it out.
Go here for: Amana-Refrigerator-Parts
RepairClinic.com
logonobyline3.jpg?ver=23
appliance parts, help & more
Apr 08, 2009 | Amana Refrigerators
Sytem Humming. :S
the bios is the heart of  the computer,check the settings of bios.
Sep 04, 2008 | Microsoft Xbox 360 Console
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridgedaire glrs237zcb3
about the only thing you can do here is take the back cover off the unit see if the cooling fan for the compressor is running if it is and there is an Indian on the compressor then the compressor should be replaced if the fan isn't running then clear the fan once its running then turn the unit off for 30 Min's and try again
Feb 11, 2008 | Frigidaire GLRS237ZA Side by Side...
My kenmore refrigerator kept running.
from your description it sounds like your hearing the start relay trying to start your compressor. most likely this relay is bad and needs replacing.
Dec 18, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
109 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
