Question about Technics RP-HP1200 Headphones
RP-DH1200 Where I can get the plastic hinge which connects the earphone piece to the upper frame of a technics RP-DH1200 headphones? Mine are broken and all I need is just one of these to rescrew onto my headphone.
2 Suggested Answers
  • 1138 Answers
SOURCE: Technics headphones RP-DJ1200
You can buy replacement plugs and solder them on. Make sure you take the old one to the store when you purchase the replacement. The next thing you need to do is figure out which wire goes to which part on the plug. You can us a volt ohm meter to test the old plug and see which color of wire or which color of wire insulation matches to which part of the plug. You can also try taking the foam pad off the left earpiece and look to see if you can get the speaker plate off the earpiece. Once off you can look to see which color goes wher. There will be another wire there that connects the right earpiece to the left one. Make sure you unscrew the shield from the plug and put it over the cord facing the correct direction before you solder the plug to the wiring. Screw it to the plug after. Hope this helps.
Posted on Jul 11, 2009
HTF600
probably it's broken wire inside.....
it can be also because you are using it with wrong device....
try to connect your earphones to something else.... like stereo, computer, mp3 player.... or cellphone....
if you still have same problem, then it's because of broken wire....
if it's playing on some devices, and don't playing on some others, that means that conectors are either broken, oxided, or not compatible
Jan 13, 2014 | Panasonic RP HTF600 - Headphones ear-cup -...
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Headphone jack has a piece of connector stuck in it and it is making my speakers not work how can i fix this problem?
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
Jun 11, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
How do I install wireless headphones on a Panasonic Viera TV
Your wireless headphones work with input from the audio output to the device base. Connect this unit accordingly with the power for the unit. switch on the tv and set your headphones to the desired frequency to lock on. Hope you get this right. good day
Jul 02, 2010 | Panasonic RP-HVS20 Consumer Headphones
Jul 10, 2009 | Technics RP-DJ1200 Professional Headphones
Technics RP-DJ1200A's left speaker disconnection
If you try carefully removing the foam ear pad you might be lucky enough to find that the speaker plate is screwed to the backing cup. I hope this is true in your case. Some of them are just glued together. Hope this helps.
May 27, 2009 | Technics DJ Headphones
The left speaker is not working. only the right speaker is working. can anyone describe how i can open the case and inspect the headphones myself?
If the left earphone is completely deaf, then the problem is the input jack, and the usual solution is just to buy new headphones. I've had this problem with the earphones for my iPod.
Apr 02, 2009 | Panasonic RP-HS103 Consumer Headphones
Right speakers don't work
After taking the unit apart, I found that the speaker wire had broken, at the point where it passes through the hinge. Although the wire is reinforced with plastic in this area, wiggling the wire showed that the break was there. I removed the coating and found that both wires were broken. That was it. No problem.
Aug 05, 2008 | Altec Lansing inMotion Plus Portable Audio...
No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Nov 21, 2007 | Technics RP-HP1200 Headphones
Technics RP-HP1200 Headphones Logo
114 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
