Question about Whirlpool Refrigerators
I have a Whirlpool Princess series Model# ed20akxsn02 the Frige side is not cooling I have it on the highest setting getting 42 degrees and no cooler but the freezer is working fine? rleesteven@netzero.com
    Novelist:
  • 77 Answers
This is a common problem, and worth fixing if the frig isn't to old. The frig is making cold air just fine, which is a plus! All we need to do is get that air to circulate throughout the entire appliance.
Behind the freezer wall is a fan called an evaporator fan. This fan simply blows the air straight up the back of the freezer. From here it enters the frig at the top left and sinks to the bottom. Then it re-enters the freezer and continues its loop :D
So, either the circulation is being obstructed by something (maybe ice build up), or the fan is out.
Behind the freezer wall is the evaporator fan (that has probably stopped moving). Either ice build up (or some obstruction) has stopped it, or it has just served its time and needs to be replaced. Generally I would just replace it. You never know if it has been damaged from ice blockage or whatever the problem may be. If the motor is trying to spin and it is being held in place, bearing could be wearing out or completely gone which will just cause you more pain in the near future. So replace that puppy and you should be all set! :D I looked up your model number and your evaporator fan motor is part number 482469 and should run you between $50 and $80. good luck!
Posted on Jun 02, 2010
Refrigerator not as cool as usual?
try setting it for a lower temperature if it does not cool more then suggest you call a repair service locally
Dec 13, 2017 | Refrigerators
We have a Whirlpool model ED5shaxmb10 that the freezer is working fine and the ice maker works but the fridge portion is not as cool as it should be, it is only 42 degrees at the highest setting
You most likely a defrost problem. Look into the back of the freezer and see if you have frost building on the rear panel like in the photo=> HERE
The most likely part that will need replaced is the=> W10351625 Defrost Control Board
The next most likely parts that may be defective are the=> 2323198 Defrost Heater Assembly
and the=> W10225581 Defrost Thermostat
Like I said the defrost control board is the most likely part to fail and cause defrost to stop working. The defrost control can be found behind the control panel inside the fresh food section just above the top shelf. I am here to anser any more questions should you need answers, Thanks Sea Breeze
Dec 12, 2012 | Whirlpool Refrigerators
I have a Whirlpool Princess series Model# ed20akxsn02 the Frige side is not cooling I have it on the highest setting getting 42 degrees and no cooler but the freezer is working fine?...
Check to see if the fan inside the freezer is working... Also check if you have any frost build-up inside the freezer ..Frost buildup is an indication of either a non working defroster and/or a bad fan. Can't diagnose it with limited information.
Regards'
Dectech
Feb 14, 2010 | Whirlpool Refrigerators
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Same problem,cool freezer ,hot refrigerator
Try reducing freezer temperature. Unplug and let main control board reset. I need to assume you have the PSS26MGPABB model when I ask you to do this. I can send you the manual and assist you if you want. Let me know, Thanks Sea Breeze
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Jun 10, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
184 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
