Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I have a Kodak esp3 printer. I replaced the color
I have a Kodak esp3 printer. I replaced the color cartridge in March 2010 (used it very vew times) replaced it again May (printed 3 pages of pictures and the cartridge needs changing again. Also frequently receive an error message. I think this printer had a defect since it is no longer for sale. Is there anyway to 'fix' the problem of it running out of color so quickly. can this model be traded in on a newer model that works?
I have had exactly the same problem. I can't carry enough ink to it. Plus even more perplexing is the fact that it won't print b & w when the colour runs out and visa versa. I havent printed any colour stuff at all since replacing the colour cartridge last month and yet again it has run out. Advice / help siteuseless. If they spent as much effort with helping customers as they do with their useless junkmail then the servic would be better. Best advice steer clear of kodak printers !!!
Posted on Jun 08, 2010
Kodak ESP3 not printing
Don't have a solution but can confirm this printer seems to be full of bugs. I have reinstalled software twice which gets the printer going for a very short time only. It does not recognise the Kodak ink cartridges..! Very frustrating.
Feb 27, 2010 | Kodak ESP 5 Printer
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Have kodak esp3 printer said I needed to replace the color printer( which I have never printed before in color only in black) but okay I put in a brand new black AND a color ink cartridge it still is...
I could suggest that you contact Kodak direct as you will need to get a replacement printer. Log onto www.kodak.com and select the help and support tab. Select the online chat option and tell them about this issue.
Oct 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 installed 2 new cartridges black light
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer 3 in one kodak esp3 the ink is full
upgrade the firmware of ur printer.go to kodak.com/go/printhead support.take out printhead and ink cartridges ,reseat them again.if problem still persists,call kodak @ 1800 421 6699. they will replace ur printhead free of cost
Jul 22, 2009 | Kodak 5300 All-in-One InkJet Printer
Case No: 60198341. On the 28th July O8 I
Hi Helena, sorry to hear that you're having a few problems with your Kodak ESP3 printer. I tried to see if I could find information for you based on the case # given but couldn't find it in the system. Could you please check to see if the number is correct....thx!
Rick from Kodak
Jul 15, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP3 printer flashes red light under color ink. Kodak tech said I needed new printhead. Send one and I installed it but have the same problem.
try replacing the ink cartridges with genuine Kodak ink cartridges and if still does not work call kodak tech support as it will be a printer hardware problem......
Jun 17, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam
Yes, put it in the box and take it back, and don't look back. A paper jam is the least of it's problems. Wait till you keep track of the ink you use: 4 4X6 color pictures, and 85 black printed pages before you have to replace the inks. I know , I have one, 3 printheads replaced, and recently Kodak send a rebuilt printer. Kodak has big problems with this.
Get an HP printer.
May 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Just changed ink everything is purpleish pink esp3 kodak printe
Pink color usually indicates, color cartridge bad,
Try cleaning nozzles, head cleaner, alignment, calibration
Print off a test page,
If still bad, New cartridge, it's a bad one.
Hope this helps
Richard.
Apr 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dead printer after replacing Cartridges in Kodak ESP3 AiO Printer
You should never use a COMPATIBLE ink cartridge or a ink cartrdge from different manufacturer......if you do then you are damaging your printer yourself and no one can help you not even kodak tech support.........try using genuine ink cartridge if you look on side of the ink cartridge then you will see a code which will indicate if its genuine or not try and match those codes with the codes that i will mention if it does not match then its not genuine...........
  • 1K3156
  • 1K3157
  • 1K3178
  • 1K3177
  • 1K3189
  • 1K3190
  • 1K3627
  • 1K3622
  • 1K3629
  • 1K3638
  • 1K3620
  • 1K3621
let me know if this was helpful.......
Jan 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
416 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
