Question about Fisher and Paykel GWL11 Top Load Washer
Gwl11 washer can you let me know what the falt code for the first 5 lights are. it goes to the spin cycle and then spins a while and stops and the repeates like 5 to 6 times. what does this mean? they stay lit and then beeps till I power down. thanks for your help. Ricky
  • luisa_sgro Jun 02, 2010
    there is no fault code for the first 5 lights on.from left to right which ones are lit. please reply and i can help you further. sounds like an out of balance problem. does your machine have an EFFICIENCY button?
  • 159 Answers
Code 248.there should be paper with fault codes inside the control box area if you undo it by 2 phillips head screws.
Posted on Jun 03, 2010
  • chrizzoclark Jun 03, 2010
    This doesn't sound like a fault because according to my repair manual there is no fault code 248 They don't go that high up.This sound like the restart feature has been activated somehow,have you been playing with the buttons before this started happening,like holding down 2 buttons together for a period of time..try this.unplug from the wall for 30seconds then try it again.Let me know what happens please!.
WILL NOT SPIN/DRAIN CYCLE
Lid / out of balance switch faulty
Drip dry switch / button on
Sud save switch / button on
Apr 03, 2014 | Fisher and Paykel GWL11 Top Load Washer
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Bought the washer and dryer set about 5 years ago and have been very happy with the brand. Starting yesterday, the 29 of june the machine will not go into the spin cycle. It does everything up to that and...
Hi just read your posting.Now does the machine drain?When the machine stops does the machine beep and show an error code in lit lights?Please reply with additional information and I can help you rectify this fault.
Jun 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer is full of water almost to the top it is a fisher and paykel gwl11 is there any comon problems
Hi just read you posting.Now If you select a spin cycle does the machine start to drain the water?Where is your machine draining the water to?Is it into the laundry sink?If you select a spin cycle and it does not drain it could be your pump is faulty or jammed.Does the machine stop and beep and show an error code or a series of lights?Please reply with additional information and I can help you rectify this problem.
Jun 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Fisher and Paykel GWL11 washer will not finish a cycle. It goes to the rinse and spin part and just sounds an alarm and will not do anything else or advance any further. What would the issue be?
It would be putting up a sequence of lights across the top.that is a fault code..I don't know if it's stopping when it's trying to drain the water or if it is in fact draining the water,all i can say is if its not draining even the first load of water then it's likely to be a blocked or jambed pump.code 37 should mean pump problem.When the machine is beeping,the lights on the top row must be read from right to left in binary code.eg 128,64,32,16,8,4,2,1 these are the binary numbers for each light across the top row.Add together only the ones that are on.that will be your fault code.
May 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Maytag neptune FAV6800AWW top load washer gets to 32 minutes left and goes no further. It starts to cycle for about 5 seconds and stops for about 35 seconds... over and over and over
Is the machine in Spin Cycle when this is happening? What part of the washer selected cycle does the Cycle Status LED say the machine cycle is in.
If it’s in the Spin Cycle I think you have a clutch issue. Do you take any error codes to the LED console display such as dC or uC?
If you stop the machine in that cycle and do a Spin Only cycle will it complete?
Do you want to DIY the fix? Let me know and I will try to help…..Rich
Feb 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
305 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
